Sudden change of inflow turbulence intensity Tu |
August 30, 2016, 02:23 |
Alvin
Rep Power: 15 |
I proposed one turbulence model that rely on the evolution of turbulent kinetic energy equation to capture transition. So far in several classic test cases it can reproduce bypass, natural and separation induced transition. However the paper reviewer said that the transition prediction was too fragile. One reason he claimed was multiple solutions for the same set-up could happen. More specifically, a solution started from a laminar initial condition would converge to a different solution than the same simulation staring from a fully turbulent set-up. With T3B flat plate boundary layer, I tried that and found that a fully turbulent set-up as the initial condition could lead to a transition location backwards, but the new result was different from both fully turbulent condition and the experiment.
I begin to wonder how DNS or experiments behave. As known, T3B was almost an in-compressible case so the fully developed turbulent boundary layer as the initial field would certainly propagate to the upstream and alter the transition location. Has anyone ever studied this? |
August 31, 2016, 23:43 |
duri
Rep Power: 17 |
This is interesting. Why do you expect transition location to be same with clear initialization (laminar) and contaminated initialization (turbulent). It doesn't happen in reality. How turbulent boundary layer become laminar before transition point in the second one.
September 1, 2016, 06:35 |
#3 | |
Alvin
Rep Power: 15 |
It is not me but the reviewer of my manuscript believes that a proper transition approach would surely yield the same results regardless of the initialization. I don't really know what you mean "It doesn't happen in reality", for we can reduce the inflow intensity during the wind tunnel test. |
September 1, 2016, 07:38 |
duri
Rep Power: 17 |
Laminar flow can become turbulent. But for the same condition relaminarization would not occur in nature. So when flow is initiallly turbulent it should continue to be turbulent. In your case it appears boundary condition drive the initial turbulent flow to laminar flow. which is not real.
In wind tunnel transition doesn't occur like full scale model. Hence tripping is used to create turbulent in the boundary layers. Transition location is quite sensitive to external disturbance and turbulent intensity. In your case, probably you need to figure out which terms in your equation or bounary condition forces laminar condition in a turbulent flow. |
transition |
Displaying Turbulence Intensity in LES and creating a constant Turbulence Intensity | Anwer | FLUENT | 1 | August 8, 2016 17:59 |
Question about turbulence intensity | Anna Tian | Main CFD Forum | 8 | July 15, 2013 19:19 |
specify the turbulence intensity and the turbulence length | bennoman75 | Main CFD Forum | 0 | May 15, 2013 06:36 |
How to asses turbulence intensity | Kwiaci | FLUENT | 0 | September 3, 2012 06:48 |
Turbulence Intensity Vs CFD Simulation | Apple L S Chan | Main CFD Forum | 3 | December 15, 1998 18:28 |
