Will "filling" areas with re-circulation always eliminate that flow separation |
Michael Brooker
Rep Power: 10 ![]() |
Hi, i'm a new user here and a beginner to the field of fluid mechanics. In my little experience and human intuition when I've tried to design around flow separation I've found that "filling" these areas or essentially having the geometry follow where the natural flow wants to go seems to eliminate flow separation. For instance, in the example of a backward facing step, if you were to analyse how the flow separates and alter the geometry such that there was a transition following the natural path of the flow you would expect no separation.
My question is, is this always the case (with subsonic flows and standard conditions for air), and if not, what is the reason and could you give me some scenarios? Thanks, this is just for curiosity ![]() |
#2 | |
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
Michael Brooker
Thanks, I hadn't thought about this scenario. Is it possible that it might also work in this example? If the geometry of the flat plate started to follow the natural flow separation at that point I would imagine it would cause a locally higher pressure in that region therefore delaying flow separation due to less of an adverse pressure gradient?
#4 | |
As different example, in flow over wing sections, it is quite common to work with geometries that tend to mantain a laminar condition, however separation is a quite common phoenomenon. Trying to prevent separation or to produce a delay is a hystorical issue in aerodynamics and fluid dynamics. Prevent separation for all types of geometries and flow conditions is not possible |
duri
Rep Power: 17 ![]() |
Separation is not transition. Flat plate at zero angle of attack never separates. Flow separation can occur in laminar as well in turbulent boundary layers.
#6 | |
Flow over flat plate a zero angle of attack has separation and reattachement, unsteady and three-dimensional, due to transition! What you are thinking about is in terms of the statistically averaged velocity field that shows no separation. |
#7 | |
duri
#8 | |
duri
Vortex lift off during transition doesn't mean it is separated. It actually energize the boundary layer from main stream mixing. |
#9 |
yes, I was not enough clear using the term "transition". I dont want to say that separation happens "in" the transitional region but that separation happens thereafter in the onset of turbulent region due to the previous transion.
#10 |
Michael Brooker
Thanks for the info guys.
backward facing step, design, flow separation, recirculation |
Bad convergence for flow separation in T-junction | MelroseBing | CFX | 2 | May 17, 2016 00:59 |
Separation bubble inside a tunnel - unexpected assymetric flow | Queiroz | CFX | 8 | November 27, 2014 17:27 |
flow separation observation in fluent | itmam | FLUENT | 0 | January 16, 2014 01:04 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
Flow visualization vs. Calculated flow patterns | Francisco Saldarriaga | Main CFD Forum | 1 | August 2, 1999 23:18 |
