Spatial and temporal convergence for combustion flow simulation
Old   August 26, 2016, 08:38
Default Spatial and temporal convergence for combustion flow simulation
Samraj Manickam Palvannan
samraj is on a distinguished road
Hallo all,
I have been doing a flow simulation. the flow happens after combustion. In order to find which mesh size would help me obtain i need to do mesh convergence study. Like structural analysis, one can lock all parameters to a constant value but one with one variable and try it for different mesh sizes? Also with time convergence, since it deals with cfl criteria, i am very confused. I have two variables, cfl and time step. if i understood it correctly, the time step and cfl both influence each other over the flow process. how to approach this problem. does the process vary with the simulation tool? any help would be very much appreciated.Thanks all again
samraj is offline   Reply With Quote
Old   August 26, 2016, 10:03
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by samraj View Post
Hallo all,
I suggest to do a convergence study by taking a fixed value for the cfl on all the grids you refine. That will take a constant ratio between dt and mesh sizes
FMDenaro is offline   Reply With Quote
Old   August 26, 2016, 10:41
Hallo, Thanks for your message. I understand that. does this mean i can do both spatial and temporal convergence at the same time? Thanks
Old   August 26, 2016, 11:34
yes, this way you are sure that the all terms of the local truncation error vanishes asymptotically
Old   August 26, 2016, 12:39
Hallo,
Thanks for your message. I will try this method now. Also does this method of eliminating truncation error vary with different tools ? i need to do this on LS Dyna. I am not sure if ls dyna related doubts can be asked here. However, i request you to share your knowledge and experience regarding this. Thanks
Old   August 26, 2016, 12:42
the convergence study does not depend upon a specific code, it is a numerical methodology to assess the behaviour of a code on a known test.
Old   August 26, 2016, 12:43
hello,
Thanks. I understand that. Thanks much.
Old   August 27, 2016, 06:55
Hallo,
Would you also help me with time step value? For fixed cfl over different mesh size, how one could define the time step?should it also be a fixed one? Thanks.
Old   August 27, 2016, 07:30
once the cfl value is fixed, you compute the time step for each grid, for example in a 1D case that would give dt= cfl*h/|u|
Using a Mass Flow Rate profile with a Temporal field as a Boundary Condition Jotheman Main CFD Forum 0 October 18, 2015 10:25
Spatial accuracy vs. Temporal accuracy yhy20081016 Main CFD Forum 4 February 20, 2014 08:42
Best approach to study temporal and spatial convergence ndabir Main CFD Forum 6 July 16, 2013 11:46
Temporal and Spatial averages shahzad_munir Main CFD Forum 0 September 18, 2012 07:09
1st order temporal & 2nd order spatial Prateep Chatterjee FLUENT 0 January 19, 2003 01:31
