August 12, 2016, 09:54 |
Inhouse CFD code validation
Ivan
Rep Power: 16 |
Dear collegues !
I need an advice on the CFD code validation procedure. I have implemented CFD solver for compressible, viscid gaseous mixture of thermally ideal gases (gamma = gamma(Y_i,T), where Y_i - component mass fraction), taking into account thermal conductivity and multicomponent diffusion. Gasdynamics of the gaseous mixture works fine as I can see from the comparison between numerical solution and well-known classic gasdynamical tests (e.g. Sod's test for multicomponent shock tube flow, or Sedov problem). The question is how to verify thermal conductivity and multicomponent diffusion ? Maybe you can suggest some tests on multicomponent diffusion in the gaseous mixture with strong theoretical or experimental foundation ? For example I thought about simple diaphragm test with discontinuity in concentrations (e.g. hydrogen on the left and oxygen on the right), or discontinuity in temperature, but I cannot find any solutions for this problem with gasdynamics taken into account. Best regards, Ivan. |
Debugging technics - CFD code developing | leo_NM | Main CFD Forum | 2 | June 9, 2016 12:22 |
Future CFD Research | Jas | Main CFD Forum | 10 | March 30, 2013 13:26 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 13, 1999 00:27 |
What kind of Cmmercial CFD code you feel well? | Lans | Main CFD Forum | 13 | October 27, 1998 11:20 |
