Need your help guys in NX flow!!!
Old   August 12, 2016, 05:10
Default Need your help guys in NX flow!!!
Ashwath Suresh
Ashwath is on a distinguished road
Send a message via Skype™ to Ashwath
Hello Hi,
I am running a flow simulation inside a tube with throttle valve. In the problem, the boundary conditions are angle of throttle valve is from 0 to 90 in steps of 10. I just wanted to know whether the vavle rotates and just it is stationary at some angle.
I have attached the word file. Please let me know what to do..
Ashwath is offline   Reply With Quote
Old   November 14, 2017, 05:15
Default Lift n Drag Report
CFD Germany is on a distinguished road
First of all.
Do you know how to set up a NX Flow Simulation?
The steps you´ll have to do are.
1. Set up a Flow Simulation with your Boundary Conditions (BC´s) and use a Report/Lift´n´Drag to get the moment on your throttle valve.
2. Pressure Drop. There´s also a Report for the PD. If you need the PD from in- to outlet its easy to set up.
3. Postprocessing
4. If you want to transfer the forces into a FEM-Simulation you have to map the results. I have to look it up, how you can do it excatly, but theres also a tutorial in the NX help to do it.
Hope i could help a little
CFD Germany is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Different flow patterns in CFX and Fluent avi@lpsc CFX 6 April 17, 2012 02:22
Different flow patterns in CFX and Fluent avi@lpsc FLUENT 4 April 8, 2012 07:12
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 3, 1999 00:18
