Interpretation of turbulent viscosity
Old   August 11, 2016, 05:54
Default Interpretation of turbulent viscosity
Alex Baptistella
vemmonstr is on a distinguished road
Hello everyone,
I'm new in the forum and just got in the world of CFD.
I have a question concerning the turbulent viscosity term in the k-epsilon model. What is in general term this term and its real need? Where does it come from?
Thanks in advance.
vemmonstr is offline   Reply With Quote
Old   August 11, 2016, 10:46
Matt
fluid23 is on a distinguished road
By averaging the Navier-Stokes equations (RANS analysis) we introduce non-linear terms called Reynolds stresses which prevent a closed solution of the equations as is. You can think of these as turbulence dependent terms. One way of addressing this is the so called Boussinesq approximation. This sets the Reynolds stresses as a function of the mean flow such that a closed solution can be found but in the process introduces a term called eddy viscosity. Essentially, it is a way in which we can understand and model the dissipation of turbulent energy in the flow. It’s very much analogous to the idea of molecular viscosity (aka fluid viscosity) which dissipates mechanical energy into thermal energy through friction. This is the basis of most of the common turbulence models; k-e, k-w, spalart-allmaras, etc…
fluid23 is offline   Reply With Quote
turbulent viscosity
turbulent viscosity in k-e model orlik Fluent UDF and Scheme Programming 1 July 19, 2017 13:27
[OpenFOAM] turbulent viscosity ratio bmikuz ParaView 2 July 4, 2014 03:59
k-epsilon problem: non-physical turbulent viscosity production in coaxial free-jet Felipeb Main CFD Forum 1 July 26, 2010 18:02
Turbulent viscosity and shear rate shib FLUENT 0 June 22, 2010 13:44
Modified turbulent viscosity Christoph Oehy CFX 4 April 27, 2000 23:06
