What is Dynamic Aerodynamic Analysis?
Old   August 3, 2016, 17:50
Default What is Dynamic Aerodynamic Analysis?
samsmith
utsav is on a distinguished road
I am starting with CFD and I came across dynamic alaysis and static analysis what is the difference between them and how can perform dynamic analysis in a CFD software like ansys?
utsav is offline   Reply With Quote
Old   August 10, 2016, 18:09
Matt
fluid23 is on a distinguished road
My guess is that you are referring to steady-state vs unsteady flow. The difference here being one varies with time while the other does not. If you are doing an unsteady (dynamic) analysis you will need an unsteady solver. If you are doing a steady-state analysis (static) you will need a steady solver.
If you are using ANSYS, post your topic in the ANSYS forum and you should get some helpful responses on how to setup your model appropriately.
http://www.cfd-online.com/Forums/ansys/
fluid23 is offline   Reply With Quote
dynamics cfd
Dynamic Analysis of a Tethering cable for Aerostat sgautam Structural Mechanics 1 May 28, 2015 04:02
SOS.udf inlet parabolic velocity for aerodynamic analysis ashkan39t323 Fluent UDF and Scheme Programming 1 March 4, 2015 12:05
Dynamic Mesh Errors in Flapping wing analysis navaneeaero FLUENT 0 December 18, 2014 09:20
AERODYNAMIC NOISE ANALYSIS Nicolas CFX 5 April 4, 2007 13:41
Aerodynamic analysis of car Vikas Kumar Main CFD Forum 3 April 10, 2003 16:15
