Boundary Conditions on Divergence in Marker and Cell (MAC) |
August 1, 2016, 16:50 |
Jack
Rep Power: 10 |
Hi all,
I have been studying the Marker and Cell method by Harlow and Welsh, and had a question about the boundary condition on divergence. They suggest setting it so that the gradient of the of the divergence on the boundary is zero (div ghost cell = div cell on edge) for free-slip, no-slip, inlet and outlets. However, I am struggling to find any physical argument for this. Why not set it so that the divergence is zero on the boundary (div ghost cell = - div cell on edge)? This would also fit better with the other boundary conditions when setting the normal velocity on the edge of the ghost cell for satisfying the other boundary conditions. It also directly enforces the zero divergence condition on the boundary. The divergence in the ghost cell only comes in to play when calculating the laplacian of the divergence, and the original MAC report suggests that the laplacian of the divergence term can be left out of calculating R_(ij), so does it really matter if it might not even be used? Thanks again! |
August 1, 2016, 17:16 |
Filippo Maria Denaro
Rep Power: 73 |
are considering this paper?
http://www.cs.rpi.edu/~cutler/classe...rlow_welch.pdf could you better clarify your question? |
August 1, 2016, 17:22 |
Jack
Rep Power: 10 |
Thats the paper, but the technical report is available here: http://permalink.lanl.gov/object/tr?...eport/LA-03425
Boundary conditions are discussed on page 49. Why set D_(i-1,j) = D(i,j) so that there is no gradient? Why not set D_(i-1,j) = - D(i,j) so as to enforce zero divergence on the boundary? |
August 1, 2016, 17:42 |
#4 | |
Rep Power: 73 |
ok, so you are focusing on condition 6) in the paper. You can see it a a numerical condition enforcing homogeneous Neumann condition for the divergence on the wall. When D(i,j) tends to zero, D(i-1,j) does too. If you enforce the reflection condition D(i-1,j) = - D(i,j) you fix a linear extrapolation from the interior. Even in this case when D(i,j) tends to zero, D(i-1,j) does too. But, generally, extrapolation on the boundary is not a good choice as it can amplify oscillations and leading to instability. However, this method is very old and now much more studies are published that clarified many issues in the numerical solution for incompressible flows. |
August 1, 2016, 18:02 |
Jack
Rep Power: 10 |
OK, thank you.
How wise would it be to replace R_(i,j) by Q_(i,j) as described on page 22 of the report, thus removing the question of setting a boundary condition on divergence? Can you briefly name some of the issues and studies so that I can read more at all? What might be a better alternative method that is similarly straight forward to implement? Thanks |
August 1, 2016, 18:06 |
Rep Power: 73 |
fractional step methods (projection methods), as this one :
https://www.google.it/url?sa=t&rct=j...E_ox2w&cad=rja |
August 1, 2016, 18:19 |
Jack
Rep Power: 10 |
I have had a look at fractional step methods before. They seem very similar to the MAC method, so what advantage do they give?
I was not sure about the boundary condition on the poisson equation of d(phi)/dn = 0, or in fact 'no boundary condition on phi' that Kim and Moin suggest. Surely there has to be a boundary condition (in the ghost cells) in order to evaluate the poisson equation for phi in the domain? What about if I wanted to set a zero pressure outlet? |
August 1, 2016, 18:24 |
#8 | |
Rep Power: 73 |
if you read carefully the method, you see that the pressure equation is written in term of Div Grad phi, therefore on a boundary you will substitute directly n.Grad phi in terms of the difference between intermediate and real velocity. I suggest to check in this forum for similar posts where many details are discussed. |
August 2, 2016, 03:07 |
#9 |
Arjun
Rep Power: 34 |
I think this explains this step by step in detail
have a look http://www.inf.ufes.br/~avalli/mestr...al/griebel.pdf I read it year back so i might be wrong but i believe what he describes is marker and cell method. |
August 2, 2016, 13:59 |
#10 |
Arjun
Rep Power: 34 |
Found the code also for it. Attaching it.
boundary condition, divergence, mac, marker and cell |
Marker and Cell Grid | thatdiverguy | Main CFD Forum | 0 | January 3, 2015 15:57 |
matlab code of marker and cell method for solving 2d incompressible navier stokes eqn | sgangarapu | Main CFD Forum | 1 | August 28, 2013 11:33 |
Marker and Cell Method - a code to look at it? | kujret | Main CFD Forum | 0 | March 3, 2013 05:14 |
MAC + SOLA for free surface | T | Main CFD Forum | 1 | April 11, 2001 14:43 |
Marker And Cell method (MAC) | Albert Badal | Main CFD Forum | 0 | February 27, 1999 20:53 |
