Help regarding 1D compressible flow (Sod Shock tube)
Like Tree1Likes
Old   August 29, 2022, 07:33
Poly T
poly_tec is an unknown quantity at this point
Well, yes, you shared a code. An internet search makes it clear that it is likely not fully yours.
You just dumped the code here, without any info on: what is the problem, what you have tried, checked, verified, tested etc.
Are we supposed to do that for you?
What makes it even more frustrating is that this is for a thesis. A piece of work that should be original, reflect your own work and something you should be proud of. Instead, it is a testament to the failure of your teachers to teach you how to ask even the most basic questions. They obviously failed you. I repeat my previous statement. You have no business writing cfd codes. You need to start by learning how to pose questions, how to provide relevant information and how to stop expecting someone else will solve your problems.
poly_tec is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
Compressible Flow Pressure Outlet Back Flow okstatecheme OpenFOAM Running, Solving & CFD 1 March 21, 2018 09:11
rhoCentralFoam not reflecting shock in Shock Tube? Astaria OpenFOAM Running, Solving & CFD 5 March 4, 2012 04:07
compressible flow maria teresa FLUENT 1 September 7, 2007 17:58
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
