Help regarding 1D compressible flow (Sod Shock tube) |
August 25, 2022, 06:27 |
#21 |
Poly T
Rep Power: 3 |
the only correct response to „i need your codes“ is: I need your money.
August 25, 2022, 11:04 |
#22 |
javeria
Rep Power: 4 |
how much money🤔
August 25, 2022, 17:26 |
#23 |
Poly T
Rep Power: 3 |
I hope you realize this was a joke. Is this a homework problem?
August 25, 2022, 17:53 |
#24 |
javeria
Rep Power: 4 |
no this is not my homework and I ask for help..
August 25, 2022, 18:00 |
#25 |
Poly T
Rep Power: 3 |
well, post your code and we can have a look
August 25, 2022, 18:02 |
#26 |
javeria
Rep Power: 4 |
I haven't any idea about high resolution scheme that how I do coding for it in MATLAB
August 25, 2022, 18:06 |
#27 |
Poly T
Rep Power: 3 |
Then why do you want to code it ? First read up on the theory.
August 25, 2022, 18:07 |
#28 |
javeria
Rep Power: 4 |
I read the literature but my coding is not too much strong
August 26, 2022, 01:19 |
#29 |
Poly T
Rep Power: 3 |
then you should start with a simpler task. Show your work and we might help, but do not expect us to do the work for you.
August 26, 2022, 17:21 |
#30 |
javeria
Rep Power: 4 |
ok sure I will share my code
August 27, 2022, 07:42 |
#31 |
javeria
Rep Power: 4 |
clear all;
close all; clc; R=287; %Cv=717; gamma=1.4; rhol=1; Ul=0; Pl=100000; rhor=0.125; Ur=0; Pr=10000; c=50; delx=20/c; delt=.0004278; lambda=.001069; for i=1:1:c+1 x(i)=-10+(i-1)*delx; end for i=1:1:c+1 if (x(i)<0) rho(1,i)=rhol; u(1,i)=Ul; p(1,i)=Pl; else rho(1,i)=rhor; u(1,i)=Ur; p(1,i)=Pr; end end for i=1:1:c+1 mom(1,i)=rho(1,i)*u(1,i); %t(1,i)=p(1,i)/(rho(1,i)*R); e(1,i)=p(1,i)/((gamma-1)*rho(1,i)); energ(1,i)=(e(1,i)+.5*u(1,i)^2); energrho(1,i)=energ(1,i)*rho(1,i); end for n=2:1:30 for i=2:1:c rho(n,i)= .5*(rho(n-1,i-1)+ rho(n-1,i+1))-.5*lambda*(u(n-1,i+1)*rho(n-1,i+1)-u(n-1,i-1)*rho(n-1,i-1)); mom(n,i)= .5*(mom(n-1,i-1)+ mom(n-1,i+1))-.5*lambda*(u(n-1,i+1)*mom(n-1,i+1)+p(n-1,i+1)-p(n-1,i-1)-u(n-1,i-1)*mom(n-1,i-1)); energrho(n,i)= .5*(energrho(n-1,i-1)+energrho(n-1,i+1))-.5*lambda*((u(n-1,i+1)*energrho(n-1,i+1)+p(n-1,i+1)*u(n-1,i+1) - u(n-1,i-1)*energrho(n-1,i-1)+p(n-1,i-1)*u(n-1,i-1))); energ(n,i)=energrho(n,i)/rho(n,i); u(n,i)=mom(n,i)/rho(n,i); e(n,i)=energ(n,i)-.5*u(n,i)^2; %t(n,i)=e(n,i)/Cv; p(n,i)=(gamma-1)*rho(n,i)*e(n,i); end rho(n,1)=rho(1,1); rho(n,c+1)=rho(1,c+1); mom(n,1)=mom(1,1); mom(n,c+1)=mom(1,c+1); e(n,1)=e(1,1); e(n,c+1)=e(1,c+1); %t(n,1)=t(n,2); %t(n,1)=e(n,1)/Cv; %t(n,c+1)=t(n,c); %t(n,c+1)=e(n,c+1)/Cv; p(n,1)=p(1,1); %p(n,1)=rho(n,1)*R*t(n,1); p(n,c+1)=p(1,c+1); %p(n,c+1)=rho(n,c+1)*R*t(n,c+1); u(n,1)=u(1,1); %u(n,1)=mom(n,1)/rho(n,1); u(n,c+1)=u(1,c+1); %u(n,c+1)=mom(n,c+1)/rho(n,c+1); end t=plot(x,p(30,,'or'); axis([-10 10 0 100000]) t=plot(x,u(30,,'or'); axis([-10 10 -150 450]) t=plot(x,rho(25,,'or'); axis([-10 10 0 1.1]) |
August 27, 2022, 07:43 |
#32 |
javeria
Rep Power: 4 |
i need the pressure, velocity and density plot but in this code not generate
August 27, 2022, 07:57 |
#33 |
javeria
Rep Power: 4 |
and second this one
August 27, 2022, 08:54 |
#34 |
Filippo Maria Denaro
Rep Power: 73 |
August 27, 2022, 16:25 |
#35 |
javeria
Rep Power: 4 |
i do not understand the python.. matlab please
August 27, 2022, 16:36 |
#36 |
Poly T
Rep Power: 3 |
Honestly, dude, if you cannot figure out how to translate python into matlab or vice versa, you should stop trying to write cfd codes. No one here will spoon feed you. Stop this or put serious work into it. You come across as a whiny high school kid who wants others to do the homework for him. If you have a direct question, ask - but stop trying to leech.
August 29, 2022, 05:47 |
#37 |
javeria
Rep Power: 4 |
I just asked for help so why you mind it. I am stuck I used maacormack, laxwendroff and roe's scheme. Now i need some other scheme to compare the results and submit my thesis. If you are not helping me ignore.
August 29, 2022, 05:49 |
#38 |
Poly T
Rep Power: 3 |
I mind because you are not asking for help. You are asking „solve my problems for me because I am too lazy to even formulate a meaningful question“.
August 29, 2022, 05:52 |
#39 |
javeria
Rep Power: 4 |
I asked to share someone matlab codes then i will make changes in it according to my problem
August 29, 2022, 05:57 |
#40 |
javeria
Rep Power: 4 |
so please if someone can help me let me know. Because i will have submit my thesis also by tomorrow
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
Compressible Flow Pressure Outlet Back Flow | okstatecheme | OpenFOAM Running, Solving & CFD | 1 | March 21, 2018 09:11 |
rhoCentralFoam not reflecting shock in Shock Tube? | Astaria | OpenFOAM Running, Solving & CFD | 5 | March 4, 2012 04:07 |
compressible flow | maria teresa | FLUENT | 1 | September 7, 2007 17:58 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 13:19 |
