dynamic mesh for the impeller with rotational and downward motion
Old   July 11, 2016, 05:59
Default dynamic mesh for the impeller with rotational and downward motion
Jas
socreate is on a distinguished road
The geometry is like this: in a cylinder, there is a impeller with rotation and downward translation, and gas flow is introduced from the bottom (velocity inlet). Now, I have two ideas but not sure which one is better:
1) use MRF/SRF for impeller (rotation+translation) while layering dynamic mesh for the bottom interface of the zone which wraps the impeller. There maybe a problem as fluent documents say there should no normal motion to the interface of SF/MRF.
2) use MRF/SF for impeller (only rotation) while layering dynamic mesh for the velocity inlet boundary. I am puzzled of this one. Are there some problems if I use specify the velocity inlet boundary as the dynamic mesh.
Are there are other method for this problem.
Look forwarding to your help. Thank you very much.
Best wishes,
socreate
socreate is offline   Reply With Quote
