3D mesh generator
Old   January 21, 2000, 15:40
Default 3D mesh generator
Gassan Abdoulaev
Hello! I'm looking for a 3D mesh generator, which should be able to generate BOTH tetrahedral AND hexahedral meshes (structured or unstructured), depending on a user-specified option. Any advice? Thank you!
Old   January 21, 2000, 15:57
Default Re: 3D mesh generator
yangang bao
It's too difficult. For tetra elements, maybe you can find some generators which can do some practical jobs. For hexa elements, many claim they can do, but most results are frustrating.
Check the following website:
http://www.andrew.cmu.edu/user/sowen/softsurv.html
Old   January 22, 2000, 17:42
David
If you are look for fully automatic meshing then the following ICEM CFD modules may be of interest;
ICEM CFD TETRA - is a fully automatic TET mesher. Unlike most other meshing tools for TETS no surface mesh is required as a start point. The volume and surface are made together based on target cell sizes. Automatic cell sizing can be done to capture features in the CAD.
ICEM CFD AUTOHEXA - generates HEX and TET meshes automatically from primative shapes. Designed for electronic cools and enviromental studies. All HEX meshes have body fitted O-meshes.
ICEM CFD HEXA - not automatic but may time saving features; Automatic Bunching Automatic O-C grids Automatic Face / edge assoc. Meshing of CAD with holes and overlaps.
If you require more info then see;
www.icemcfd.com
or
www.icemcfd.co.uk/demos.html - for a downloadable movie demo of HEXA and TETRA.
Hope this helps.
David
Old   January 24, 2000, 09:54
Default about QUICK
marko
HI!
Do you know a good book about QUICK scheme?
marko
Old   January 25, 2000, 12:20
Farid Moussaoui
You may see the GRUMMP home page. http://tetra.mech.ubc.ca/GRUMMP/index.html
It is expected that this code will do hybrid grids.
Good Luck.
Farid++
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 01:27
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
Mesh generator for marine propellers clhona Main CFD Forum 5 September 4, 2006 07:31
