I am working on a natural convection problem and am using the using the unsteady formulation of the MAC method given in Hoffmann (pg 321-322). Although the book says that pressure boundary conditions are not needed for the staggered mesh, the equation for pressure includes pressure outside the boundary. Thanks for your help Ravi |
Ravi If you are upto something in MAC you must have defined "ghost cells" which are actully outside the physical domain of interest but are required (and hence defined) for satisfying boundary conditions. These serve the purpose for defining boundary conditions for all variable including pressure. However, if you are trying to find pressure ON THE SURFACE (like for calculating drag and such things),then you have to perform some arithmetic gymnastics which comes after you have finished computing. Chetan
I have defined ghost cells outside the boundary but I do not know the pressure boundary conditions for the problem that I am working on.
Thanks Ravi |
Ravi
As the famous saying goes "there are no boundary conditions for pressure" you can't do much. Pressure is a floating value in the sense that it is relative. That is the essence of this method (others also). One starts with some initial conditions (for all variables). Then these are updated by solving the momentum equation U(n+1,i,j,k) = U(n,i,j,k) + DeltaT*Other terms similar expressions for other variables. n is time index and i,j,k are spatial indices. Other terms are known values (if you are on the first (time) iteration the initial conditions constitute these OTs. If you are somewhere in the middle of the computation the results from the last itreration are there). Then you take these updated values and see if the continuity equation is satisfied. If no, take a fraction of the non-zero value (divergence) and update velocities and pressures (standard expressions) and go back to your momentum equation. Obviously, these steps are performed for the "real" cells only. Meaning if you had IMAX cells in X-direction including two ghost cells, you do DO I=2,IMAX-1. Now, here is when you ask where are the pressure boundary conditions. The answer is the same old saying (say above). So, what happens is that the pressure is given some initial value (Assume 0.00 for the full field) and it gets updated as per the above steps. It floats about the initial value you gave. Regards |
Thanks
Ravi |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Pressure far field boundary conditions not respected?! | Bedotto | FLUENT | 4 | August 17, 2010 04:42 |
Few simple questions concerning boundary conditions (pressure) | milos | OpenFOAM Pre-Processing | 1 | March 21, 2009 07:08 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 6, 2008 23:17 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
