XFlow Naca 0012 Validation
Old   June 27, 2016, 07:48
Default XFlow Naca 0012 Validation
Berkay Yasin YILDIRIM
Mythorpios is on a distinguished road
Hello. I am trying to validate XFlow results. I have started with analyzing NACA 0012 for Re 3000000. I have generated 3D NACA 0012 with 10k points,and analyzed in 2D. I could not get close results to the experimental airfoil data. I used 0.2 resolved scale, around 0.0003m target resolved scale and 0.004m wake resolution. It took 1.5 hours but not a valid result. How can I increase accuracy or what can be wrong about my approach? Thank you
Mythorpios is offline   Reply With Quote
Old   June 27, 2016, 14:05
Matt
fluid23 is on a distinguished road
you have 10k nodes or cells? either way, your mesh sounds much too coarse for this analysis.
what do your wall y+ values look like and what turbulence & wall models are you using?
fluid23 is offline   Reply With Quote
Data for NACA 0012 Muntazir Main CFD Forum 1 March 28, 2023 02:59
How to import NACA 0012 Profile in Gridgen maplepink Main CFD Forum 17 May 7, 2013 14:01
NACA 0012 Case Will Not Converge dancfd OpenFOAM Running, Solving & CFD 6 November 14, 2011 20:09
Problems with flat plate and NACA 0012 Lift/Force Harly FLUENT 0 June 18, 2007 11:02
NACA 0012 simulation results Luis FLUENT 3 February 15, 2006 12:42
