Geometry of Ambient?
Old   June 20, 2016, 12:15
Default Geometry of Ambient?
Micah G Bullock
NachtErfinder is on a distinguished road
Hello All,
I'm new to CFD, and I'm not sure if I'm using the proper nomenclature. Please correct any mistakes if you see them! I'm trying to model a turbulent jet exhausting into open air, and I have a few questions about the geometry of the ambient model.
Should my ambient be modeled as a cone, with the angle corresponding to the growth rate of the jet outer boundary?
Or should it be modeled as a large cylinder, to allow the boundaries not to be too close to the outer boundary of the jet?
Also, should I put 0 gauge pressure Boundary Condition just at the end of the cone/cylinder, or everywhere on its faces?
The geometry of the ambient effects the Reynolds number, so I want to be sure to get an accurate 3D model.
Thanks in advance for your help!
NachtErfinder is offline   Reply With Quote
3d model, geometry, turbulent jet
[ICEM] Volume Meshing Problem; YOUR GEOMETRY HAS A HOLE mariachi ANSYS Meshing & Geometry 5 May 30, 2018 03:52
Running CFD parallel. There is no geometry file! CrashLaker SU2 6 April 10, 2014 04:08
[CAD formats] translating geometry from Abaqus to OpenFOAM skuznet OpenFOAM Meshing & Mesh Conversion 3 January 10, 2014 14:49
Geometry for Confined Circular Jet Greatness FLUENT 0 October 1, 2013 06:04
2D geometry to 3D geometry Sgonzalezg ANSYS Meshing & Geometry 11 April 8, 2011 12:02
