June 20, 2016, 06:07 |
Problems with own CFD
Piotr Pierwocha
Rep Power: 10 |
Hello everyone!
I am creating my own solver of unsteady Stokes flow in 2D(pressure at the inlet rises linearly and stop after few seconds). At first I solve and then computed pressure is put into Stokes equations. It bases on finite difference method and uses Conjugate Gradient Method to solve the pressure equation. Next the stokes equations are solved using ADI algorithm and CGM. First step of time is okey, because the solution is zero(so it is put during initiazation). Unfortunately in next step when pressure at the inlet rises pressure don't want to converge. It is linear problem and theoritically it should converge(matrix from laplace equation is symmetricall and PDM) in some cases slowly but still it should converge. Unfortunately in my case calculations are diverging. I have checked everything but I wasn't able to find an error. Have anyone got some ideas how to find where is the problem ? |
June 20, 2016, 07:07 |
Filippo Maria Denaro
Rep Power: 71 |
I don't understand the Laplace equation for the pressure...
June 20, 2016, 07:26 |
Piotr Pierwocha
Rep Power: 10 |
If take a divergence of Stokes Equation(incompressible), you will get Laplace equation for pressure.
June 20, 2016, 08:05 |
Rep Power: 71 |
be carefull, numerically the diffusive terms in the momentum equation produce a source term into the pressure equation, that is Div (1/Re Div Grad v). The bc for the normal derivative of the pressure must ensure the compatibility
June 20, 2016, 09:50 |
Piotr Pierwocha
Rep Power: 10 |
Problem found, my matrix turn out to be not symmetricall. Thank you for advice.
June 21, 2016, 06:25 |
solver controle
AHMED LAOUARI
hi everyone
I have a question concerning the difference between conservative and aggresive length scale option for simulation |
January 18, 2020, 12:31 |
Dpm
hossein
Hi Dears
could you please help me about solid particle injection in liquid phase? particles have injected to inlet but why they don't escape from outlet? |
ICEM CFD Meshing Problems: Hexa Dominant | Evan | CFX | 6 | July 3, 2006 12:37 |
Technical Problems at CFD Online | Jonas Larsson | Main CFD Forum | 0 | May 6, 2005 13:35 |
ASME CFD Symposium, Atlanta, July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | September 13, 2000 04:48 |
CFD for fans & blower housings | David Carroll | Main CFD Forum | 8 | August 24, 2000 17:25 |
ASME CFD Symposium, Atlanta, July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | August 21, 2000 04:49 |
