Momentum Source Term in SIMPLER Algorithm
Old   June 12, 2016, 12:46
Default Momentum Source Term in SIMPLER Algorithm
ravachol is on a distinguished road
Hello all,
I am trying to write a code based on SIMPLER algorithm of Patankar by following the book of Versteeg. There is no source term for my study, I am imposing the exact values of the boundary points on a staggered grid. Do i still need to define any value to the b (momentum source term) in the momentum equation or it is just needed for implementing boundary conditions?
a_{e}U_{e}=\sum_{nb}a_{nb}U_{nb}+b+\left(p_{P}-p_{E}\right)A_{e}
Any idea will be greatly appreciated,
Thanks in advance
ravachol is offline   Reply With Quote
Old   June 12, 2016, 15:10
Arjun
arjun will become famous soon enougharjun will become famous soon enough
If there is no force for example say gravity etc, then b is 0.
Originally Posted by ravachol View Post
Hello all,
Thanks in advance
arjun is offline   Reply With Quote
Old   June 15, 2016, 08:17
erkan is on a distinguished road
Thank you very much Arjun,
I am using air as working fluid, so I will neglect the weight of the fluid. Then the two dimensional momentum equation for this case would be:
a_{p}U_{p}=a_{w}U_{w}+a_{e}U_{e}+a_{n}U_{n}+a_{s}U_{s}+\left(p_{P}-p_{E}\right)A_{e}
Timeo hominem unius libri
erkan is offline   Reply With Quote
finite volume, pressure and velocity, simple, simple algorithm, staggered grid
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 04:04
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 14:59
How does fluent handles the momentum source term? QBeast FLUENT 0 April 22, 2013 15:12
