SimpleFoam diverging with bounding omega error
Old   June 8, 2016, 08:26
Default SimpleFoam diverging with bounding omega error
anonymous
altair279 is on a distinguished road
I am running a case with flow past a tidal turbine with a cylindrical support monopile. There is a coin shaped inner domain with the turbine rotor in it and then there is the outer domain.
When I run it as an unsteady case (from time, t=0) with pimpleDyMFoam everything runs fine. But I want to run it as a steady case first and then use this solution as the initial condition of the transient case so that I can save some time on the transient run. So when I try to run simpleFoam with MRF, the case crashes with a bounding omega error( bounding to really large values).
When I ran the steady case with just the turbine rotor without any cylindrical monopile, the case runs fine. Similarly when I run a case with just the cylindrical monopile without any turbine (just like flow past a cylinder), that runs fine too. It's the interaction between these two which is causing a problem in steady state but not in unsteady state.
Can someone please help?
altair279 is offline   Reply With Quote
bounding error, openfoam 2.3.x, pimpledymfoam, simplefoam convergence
[OpenFOAM] an error in Calculator's equation immortality ParaView 12 June 29, 2021 01:10
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 03:32
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 06:07
