Performance of k-omega in low Re flows
Old   May 30, 2016, 20:43
Default Performance of k-omega in low Re flows
RacMat
rvl565 is on a distinguished road
I have been simulating low Re flows ( ReTheta ~ 2500 ) over a ZPG flat plate. I saw that neither the k-omega nor the SST (in OpenFOAM) is able to give the correct log law profile nor the correct Cf. Has anyone seen this before? Are there any references that discuss this behaviour of the models?
I just wanted to check if I am doing something wrong!
I have tried the two different boundary conditions : the default wilcox omega boundary condition with the 6 *() and the one suggested by menter 60*() for both the models.
Thanks!
rvl565 is offline   Reply With Quote
Old   June 10, 2016, 04:53
RacMat
my bad, somehow i didnt have the correct y+ :P
Old   June 17, 2016, 14:20
Default fully turbulent?
Alberto
malv83 is on a distinguished road
Are you using the fully turbulent models? because you should try transitional models. " Prediction of transitional and fully turbulent flow using an alternative to the laminar kinetic energy approach" is a very good transitional model
malv83 is offline   Reply With Quote
flat plate, komega, komegasst, low re flows, zpg
low Mach compressible flows venkataramana OpenFOAM 9 February 22, 2019 05:52
how to calculate the omega at inlet boundary in k omega sst Scabbard OpenFOAM Running, Solving & CFD 2 September 30, 2014 14:06
problem from k epsilon to k omega NJG OpenFOAM Running, Solving & CFD 0 April 15, 2013 09:24
"Glitches" in k and omega buffi OpenFOAM Running, Solving & CFD 8 January 29, 2013 04:57
Low Re number flows Wu Chun-Kai Main CFD Forum 17 July 1, 1999 21:24
