model set-up problem via ICEM and/or COMSOL
Old   May 30, 2016, 17:16
Post model set-up problem via ICEM and/or COMSOL
ChenYe
chenye1717 is on a distinguished road
Hello all,
I need to set up a membrane configuration as shown in Fig 1. I built this configuration in ICEM. Then I want to generate the surface mesh for this configuration, since ICEM CFX could not output the 2D mesh information, I need to export the geometry from ICEM and then import it into COMSOL. However, after importing into COMSOL in iges format, the configuration changes as Fig 2 presents (the top parts missing strangely).
The object is to generate the Tri surface mesh for this configuration in Fig 1 and get the node coordinates and connectivity as well. Do you guys have any ideas or experience to achieve this? (Maybe some other software?)
Thanks a lot.
chenye1717 is offline   Reply With Quote
comsol, icem
Problem with k-epsilon model torkness FLUENT 2 February 27, 2015 03:44
Trying to set up Moving Mesh Problem dreamchaser CFX 5 December 15, 2014 01:07
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Air-lift model with hot gases and water. Time step problem. PauliusRap FLOW-3D 0 August 4, 2014 05:47
Problem while rotating model in icem cfd on ubuntu highhopes Hardware 0 November 15, 2011 06:19
