Need help with a Valve multistage trim.
Old   May 26, 2016, 00:27
Default Need help with a Valve multistage trim.
KS Park
kortaz is on a distinguished road
i am trying to do multistage trim in the valve in fluent.
the temperature is 325 Celsius and inlet pressure is 194.8 bar.
I have input the water data at this temperature and used sstke.
the results should show 129 bat at outlet.
but it shows much lower pressure than calculation results.
could you anyone help me with this case please.
I do appreciate any help regarding this case!!!!
Thanks in advance!!!
kortaz is offline   Reply With Quote
multistage cage, trim, valve simulation
udf for valve closing a pipe using dynamic mesh chem engineer Fluent UDF and Scheme Programming 2 May 13, 2017 10:39
Modelling an initially closed valve which a fluid opens siw CFX 1 April 26, 2014 07:32
Gate valve flow simulations... nikesh FloEFD, FloWorks & FloTHERM 5 January 28, 2014 02:31
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
Valve Forces in CFdesign Mike Clapp Main CFD Forum 3 March 8, 2001 15:09
