Python Doublet + Uniform Flow // Streamfunction Polar Plot Help
Old   May 25, 2016, 04:41
Default Python Doublet + Uniform Flow // Streamfunction Polar Plot Help
not_real_name
nn2e11 is on a distinguished road
Python,CFD and cfd-online newbie here.
I am using Spyder (Python 3.5) and I managed to plot my streamfunction in cartesian coordinates.
I tried transforming and plotting in polar coordinates but I am not sure that what i have done is correct.
I am not even sure what the plot should look like :/
When I run the code the result is: [See attached picture]
The code is this:
import numpy
from matplotlib import pyplot
from matplotlib import cm
N=1000
r_min, r_max = 0,1
theta_min, theta_max = 0,2*numpy.pi
r=numpy.linspace(r_min,r_max,N)
theta=numpy.linspace(theta_min, theta_max,N)
X,Y=numpy.meshgrid(r*numpy.cos(theta),r*numpy.sin(theta))
kappa = 1
r_doublet, theta_doublet=0,0
def velocity_doublet(strength, rd, thetad, X, Y):
    u = - strength/(2*numpy.pi)*((X-rd*numpy.cos(thetad))**2-(Y-rd*numpy.sin(thetad))**2)/((X-rd*numpy.cos(thetad))**2+(Y-rd*numpy.sin(thetad))**2)**2
    v = - strength/(2*numpy.pi)*2*(X-rd*numpy.cos(thetad))*(Y-rd*numpy.sin(thetad))/((X-rd*numpy.cos(thetad))**2+(Y-rd*numpy.sin(thetad))**2)**2
    return u, v
def stream_function_doublet(strength, rd, thetad, X, Y):
    psi = - strength/(2*numpy.pi)*(Y-rd*numpy.sin(thetad))/((X-rd*numpy.cos(thetad))**2+(Y-rd*numpy.sin(thetad))**2)
    return psi
# computes the velocity field on the mesh grid
u_doublet, v_doublet = velocity_doublet(kappa, r_doublet, theta_doublet, X, Y)
# computes the stream-function on the mesh grid
psi_doublet = stream_function_doublet(kappa, r_doublet, theta_doublet, X, Y)
#pyplot.streamplot(X, Y, u_doublet, v_doublet,
               #density=2, linewidth=1, arrowsize=1, arrowstyle='->')
#pyplot.scatter(r_doublet, theta_doublet, color='#CD2305', s=80, marker='.');
#ax = pyplot.subplot(111, polar=True)
#ax.plot(X,Y, u_doublet,v_doublet, color='r', ls='none', marker='.')
u_inf = 1.0  # the speed of the freestream
u_freestream = u_inf * numpy.ones((N, N), dtype=float)
v_freestream = numpy.zeros((N, N), dtype=float)
psi_freestream = u_inf * Y
u = u_freestream + u_doublet
v = v_freestream + v_doublet
psi = psi_freestream + psi_doublet
pyplot.scatter(r_doublet*numpy.cos(theta_doublet), r_doublet*numpy.sin(theta_doublet), color='b', s=500, marker='o')
ax.contour(X,Y, psi, levels=[-1,1,N], colors='#CD2305',linestyles='solid')
To compare, these are the stream plots of the doublet [upper plot] and of the doublet + uniform flow superposition [lower plot]
Thank you for your time
nn2e11 is offline   Reply With Quote
cfd, doublet, python, sink, source
Too high omega and k values in vortex flow simulation thomas. OpenFOAM Running, Solving & CFD 9 March 30, 2016 07:45
Modified pimpleFoam solver to MRFPimpleFoam solver hiuluom OpenFOAM Programming & Development 12 June 14, 2015 22:22
[swak4Foam] Air Conditioned room groovyBC Sebaj OpenFOAM Community Contributions 7 October 31, 2012 15:16
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 10:03
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
