Open channel flow with icoFoam solver in openFoam
Old   May 23, 2016, 09:03
Default Open channel flow with icoFoam solver in openFoam
Yash Lakhani
yash lakhani is on a distinguished road
Hello Everyone,
I am new to CFD as well as to openFoam. I am trying a simple case of open channel flow using icoFoam solver. My geometry is a simple cuboid channel of width 0.4 m height 0.6 m and length 9m. I am neglecting the air above it and just solving it as a flow with water. The flow is steady uniform flow. Therefore the height of the water level and the velocity will be constant.
I have specified my inlet velocity and have specified pressure at outlet as atmospheric pressure and have specified the viscosity of water in transport properties file. I have used salome to generate my mesh and then exported it as unv and created the polymesh folder for openFoam. When i run the case and use paraView to visualise it, I see nothing happening. Everywhere it shows 0 velocity except at inlet where it shows the velocity specified. I will be very thankful if anyone can help.
I have changed my controldict file
startTime 0;
endTime 26;
deltaT 0.005;
writeControl timeStep;
writeInterval 80;
purgeWrite 0;
writeFormat ascii;
writePrecision 12;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
runTimeModifiable yes;
but still nothing is happening
Thanks in advance
File Type: gz 0.tar.gz (598 Bytes, 7 views)
File Type: gz system.tar.gz (925 Bytes, 3 views)
Last edited by yash lakhani; May 23, 2016 at 09:29. Reason: changed controldict file but still not working
yash lakhani is offline   Reply With Quote
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 07:42
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Open Channel Flow forsumit FLUENT 0 October 1, 2009 03:01
