How it works-Sports car diffuser |
View Poll Results: What does an undertray diffuser on a sports car do | |||
Creates Lift force | 0 | 0% | |
Creates Downforce | 3 | 100.00% | |
Voters: 3. You may not vote on this poll |
May 19, 2016, 09:24 |
Anonymous
What I know: Nozzle increases the fluid velocity and decreases the pressure. Diffuser (a divergent pipe) in a general sense decreases the fluid velocity and increases the pressure.
Now apply this to car undertray: Diffuser at the end of the undertray should decrease air velocity and increase air pressure. This increase in air pressure below the undertray should create LIFT. Paradox: Diffuser at the end of car's undertray actually creates Downforce!! Can anyone solve this paradox? Thanks in advance! |
May 19, 2016, 16:21 |
Matt
Rep Power: 18 |
You are forgetting 2 things:
1) the effect of the undertray as a whole, the nozzle and throat sections will create more downforce than the 'lift' of the diffuser. the diffuser is only there to slow the air back down before it dumps back out the back which will reduce drag penalty of the system. 2) ground effect and the air moving over the top of the car will still result in a net downforce even in the diffuser, I believe. |
aerodynamics, downforce, sports car, undertray diffuser |
Boundary Conditions | Thomas P. Abraham | Main CFD Forum | 20 | July 7, 2013 06:05 |
Car park ventilation and impulse fans | guillaume | Main CFD Forum | 12 | June 27, 2011 12:16 |
How to generate the cylindric velocity components of a simple annular diffuser | undeadking | CFX | 0 | May 20, 2011 07:56 |
Flow on a car! | John222 | CFX | 3 | January 24, 2011 19:43 |
CFD for a Soap Box Derby car | Dean Christakis | Main CFD Forum | 0 | July 6, 1999 02:09 |
