May 12, 2016, 02:06 |
Propeller Analysis
SELANGOR, MALAYSIA
Rep Power: 10 |
Hi everyone,
I'm vry new to ANSYS Fluent. So basically I would want to run analysis to determine the aerodynamic properties of a 10 x 7 inch propeller blade. I've some questions: 1) Is it possible to run static propeller analysis? 2) If I would want to make it moving at certain RPM, how do I do it? 3) How do I run the analysis to determine the thrust and power coefficient of the blade? 4) Do I run it with laminar or turbulence? Since my Reynolds number at 75% is 50669 at 3000rpm. Do enlighten me please. Thank you in advance |
Underwater Propeller CFD analysis with Ansys CFX | Alaeddine | CFX | 7 | March 30, 2018 02:37 |
Propeller Fluent Analysis | zizie | FLUENT | 2 | May 16, 2016 23:44 |
Propeller thrust analysis | euclid | ANSYS | 0 | June 24, 2015 10:39 |
Flow Analysis Around Aircraft with Propeller Effect | theengineer | Mesh Generation & Pre-Processing | 0 | August 13, 2013 06:37 |
propeller CFD analysis | cfd_analysis | FLUENT | 0 | December 18, 2012 13:45 |
