Hello all,
This question is for the ones of you who are more experienced in XFlow. I am using XFlow to do an acoustics simulation on a vending machine. I got two fans for cooling on the bottom side and two small motors on top for which I have values for noise. The fans are set to enforced movement and they rotate at a given speed therefore, moving air and generating noise. So I get some results though..but incomplete. I am not finding anything on how to put some noise values on the small motors. Is there a way you could define, let's say a point that actually generates noise, increasing sound pressure levels? How else would I approach this? Please let me know if you need more information or if I was not clear enough. Looking forward to your replies. Thank you, Dan |
cfd acoustics, noise, noise generation, xflow |
Vortex generators meshing using ICEM CFD | Sanuka | Main CFD Forum | 0 | March 30, 2016 05:23 |
XFlow file import problem | shakee93 | Main CFD Forum | 0 | June 10, 2015 03:10 |
Boundary Layer Noise Source Model | Andrew | FLUENT | 0 | January 12, 2009 22:47 |
Turbo noise macro | Barri | CFX | 0 | May 21, 2008 09:26 |
Noise | Heinz Wilkening | Main CFD Forum | 13 | January 19, 2000 05:22 |
