Rising thermal bubble in adiabatic atmosphere
Old   May 5, 2016, 13:07
Default Rising thermal bubble in adiabatic atmosphere
Mihir Makwana
mihirmakwana6 is on a distinguished road
I am trying to simulate a warm bubble(air) that rises in an adiabatic atmosphere using FVM.
The paper that i am reffering to is
http://www.sciencedirect.com/science...21999107005384
The problem is defined in section 3.2) case 2 : Rising thermal bubble
where it is mentioned that they are using no-flux B.C at all boundaries.
Based on section 4.4.2 No-flux B.C, it is clear that no-flux B.C mean that velocity normal to boundary is zero along with gradient of tangential velocity being zero ( i.e free slip B.C at all boundaries)
The kind of equations that i am solving are
1) continuity eqn
2) momentum eqn
3) pressure correction eqn
Thus i need B.C for density, velocity and pressure correction at all boundaries
Now, velocity B.C is obtained based on free slip.
But what about the B.C for density and pressure correction ???
Based on the problem definition, what can be B.C for density and pressure correction ?
Please help.
Thanks in advance.
mihirmakwana6 is offline   Reply With Quote
Old   May 5, 2016, 14:11
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
I am not sure to understand you in what you wrote and now I cannot access the paper, I suppose pressure correction should imply the solving of the continuity equation.
What set of equations are you solving?
FMDenaro is offline   Reply With Quote
Old   May 5, 2016, 14:46
Mihir Makwana
As atmospheric flows occurs at low mach number, i am using the following low mach number equations ( these are compressible N.S equations which are modified to capture low mach number effects : here pressure is split as base pressure + M^2 * pressure_pertubation i.e p_zero + M^2*p_two)
The continuity and momentum equations are
http://i.imgur.com/2Kr1hxT.jpg
The energy equation is converted to pressure equation and that is in turn converted to a pressure correction( dp(2) ) equation which is
http://i.imgur.com/DvG7sBo.jpg
In the pressure correction equation, terms on RHS are source terms
Also, i have applied time integration to the pressure correction equation.
The snippets from the paper which discuss the problem are
1) section 3.2 : case 2 : Rising thermal bubble
http://i.imgur.com/RUZ307C.jpg
2) section 4.4.2 No-flux B.C
http://i.imgur.com/OIzD8Fp.jpg
In the paper the set of equations used are different from the one that i am using
Also, based on my calculations Reynolds number for the flow is approx 10^7.
Last edited by mihirmakwana6; May 5, 2016 at 16:18. Reason: images were not accessible
Old   May 5, 2016, 16:02
the images are not available....
Old   May 5, 2016, 16:19
Mihir Makwana
i have edited the post. please have a look at it.
Old   May 5, 2016, 16:44
from the image of the energy equation, the field p_2 is a solution of an alliptic equation, right? Therefore the Neuman condition are derived from the Grad p_2 term in the momentum under projection along the normal direction to the boundary and using the condition u.n=0
Old   May 5, 2016, 16:52
Mihir Makwana
yes the field p_2 is obtained by solving for elliptic eqn of dp_2 i.e the pressure correction equation
Due to no-flux B.C , u.n=0 thus grad_dp2 will be zero at the boundaries.
This gives the B.C for pressure correction equation.
but is this condition of grad_dp2 = 0 ,correct for the problem at hand.
i.e can we apply it for this problem
also, we need a B.C for density
Old   May 5, 2016, 17:13
Mihir Makwana
i applied the following B.C
1) grad_dp2 = 0 at all 4 boundaries
2) grad_density = 0 at all 4 boundaries ( i am not sure whether it is correct for the thermal bubble problem )
Based on the above B.C's along with free slip B.C for velocity, i ran the simulation.
But the results are not matching
I think there is some problem with the B.C that i am imposing
Old   May 5, 2016, 17:31
maybe you can find useful this recent paper and its references
http://eprints.eemcs.utwente.nl/2607...ukhvostova.pdf
Old   May 5, 2016, 18:08
Mihir Makwana
ok. thankyou sir.
I will have a look at it.
Old   May 5, 2016, 18:50
As you can read, they set (1/rho) dp/dn = 0
Old   May 6, 2016, 02:44
Mihir Makwana
so, in my case it will be (1/rho) grad(dp2) = 0 i.e. grad(dp2) = 0 at all the boundaries.
Now,
Density is obtained by solving continuity equations only for internal points
i.e. I don't have values of density at the boundaries
So, some B.C for density is needed
Last edited by mihirmakwana6; May 6, 2016 at 02:48. Reason: needed to add something
Old   May 6, 2016, 04:10
you can consider to solve the density equation in a FV around the node boundary...otherwise, an approximation such as d rho/dn = 0 (actually, the normal derivative should be expressed by the state equation)
Old   May 6, 2016, 05:24
Mihir Makwana
i did implement d rho/dn = 0 at all boundaries but it is not giving the expected result
Old   May 6, 2016, 05:26
of course that is not a good approximation in specific cases, you can try to solve the density equation at the boundary
Old   May 6, 2016, 05:30
Mihir Makwana
is there a paper that discusses solving continuity at boundary ?
Old   May 6, 2016, 06:16
I used that many years ago in a FV formulation on unstructured grid, unfortunaltely I don't remember those references.
However, it is just a local integral formulation for a FV built around the node at the wall.
A rising bubble in a stagnant liquid with two-fluid-model fs82 OpenFOAM Running, Solving & CFD 30 August 18, 2016 13:27
bubble rising problem swamysrikanth ANSYS Meshing & Geometry 3 May 31, 2016 12:09
2D bubble rising through a column of water vof64 Fluent Multiphase 0 August 20, 2014 00:42
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
