May 5, 2016, 11:09 |
Interesting pressure and velocity contours
Rep Power: 10 |
I've been analysing the 2D flow over a not-quite-circular cylinder in ANSYS Fluent. The analysis has been transient and run long enough to produce this lift coefficient plot. It oscillates at the vortex shedding frequency as would be expected and its time-average gives a lift coefficient of -0.307.
With this downwards lift in mind, I don't understand these total pressure and velocity magnitude plots. There seems to be higher pressure AND higher velocity on the underside of the shape, which would be impossible according to Bernoulli. Also, wouldn't the higher pressure underneath suggest upwards lift and give a positive lift coefficient? And what can can we interpret from the fact that the shed vortexes take a path at an angle to the flow? I'd really appreciate your thoughts |
May 5, 2016, 12:37 |
david
Rep Power: 14 |
Let's have a look at your dynamic and static pressure distribution *wink*
May 5, 2016, 13:06 |
Rep Power: 10 |
Thanks very much for the reply, David. I don't actually have access to the data right now (it's saved on a lab computer) but I'm assuming you mean that you'd expect there to be an area of high dynamic pressure and low static pressure on the underside of the shape? That makes sense!
Any ideas why the vortices move upwards? Is this because the shape is being 'lifted' downwards? |
May 5, 2016, 14:02 |
#4 | |
Filippo Maria Denaro
Rep Power: 73 |
aerofoil, bluff bodies, contour plot, cylinder flow, lift coefficent |
Pressure Inlet VS velocity Inlet difference | Mohsin | FLUENT | 9 | January 4, 2021 11:34 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 03:15 |
Variables Definition in CFX Solver 5.6 | R P | CFX | 2 | October 26, 2004 03:13 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 10:11 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
