Lift Vs Drag?
Old   May 1, 2016, 02:18
Default Lift Vs Drag?
VAMSI YERRAGURAVAGARI
Vamsi is on a distinguished road
Send a message via Skype™ to Vamsi
Hello everyone,
In ANSYS FLUENT: for flow over a object, Could anyone tell me why the coefficient of drag reaches a constant value whereas the Coefficient of lift oscillates over time?
Thanks in advance for the reply.
Vamsi is offline   Reply With Quote
Old   May 2, 2016, 04:28
david
davidwilcox is on a distinguished road
it simply means your solution is not converged. This is of course if you are running a steady state case.
davidwilcox is offline   Reply With Quote
Old   May 2, 2016, 05:39
No. I am running a transient case.
Old   May 3, 2016, 03:38
Hamid Zoka
Hamidzoka is on a distinguished road
Hi
If there is no separation around your object constant drag coefficient can be related to viscousity which acts as a damper and can suppress the falucctuations. While the lift comes from pressure distributions on the surfaces of the object and can be subject to change when you run a time dependet simulation. Wakes and other time dependent flow structures can simply affect pressure distributions as time passes.
Regards
Hamidzoka is offline   Reply With Quote
Old   May 3, 2016, 22:12
Originally Posted by Hamidzoka View Post
Hi
Regards
Hi. Thanks for the reply. I do have flow separation on the square cylinder. So does this effect the Cd Vs time plot?
Old   May 4, 2016, 11:55
ys12 is on a distinguished road
If you are doing a transient analysis with turbulence options checked, there is no reason to expect a constant C_l value. At each instant in time the separated flow leaves a chaotic turbulent wake (no matter how small).
I think in an unsteady situation like this, a steady C_l / C_d value doesn't mean much.
ys12 is offline   Reply With Quote
Old   May 4, 2016, 11:57
michujo is on a distinguished road
I am no expert in the subject but it could be that your simulation is capturing the right behaviour.
You might want to check the Strouhal number of the vortex shedding from your simulations against experimental and numerical data from the literature. There are plenty of papers on the matter, just google "flow past a square cylinder".
Cheers,
Michujo.
michujo is offline   Reply With Quote
Old   May 8, 2016, 16:00
Default drag coef
lazzouni rima
lazzouni is on a distinguished road
how to have the drag coef in fluent thanks
lazzouni is offline   Reply With Quote
How to calculate lift, drag and lift distribution in Star CCM+? israelcasillas94 STAR-CCM+ 4 November 6, 2020 08:35
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 05:18
[OpenFOAM] Display lift and Drag in paraview SamerAli ParaView 1 May 16, 2013 12:51
Lift and Drag Monitor Point Values Converging to Zero Josh CFX 24 May 9, 2011 10:38
Correct lift but wrong pressure drag - possible? zx Main CFD Forum 4 July 27, 2007 23:38
