April 27, 2016, 13:23 |
resolution characteristics of FD schemes
Kaya Onur Dag
Rep Power: 13 |
I am looking at 2nd and 4th order central finite difference schemes and trying to understand how good they can resolve the first derivative for each given wave number.
My routine is I make a sine curve with given wavenumber k, take the derivative with given FD scheme and transfer the result into fourier space to compare the amplitude of the corresponding wave's exact derivative. I also check 2nd and 4th order cell centered schemes where I sample my sine curve on a finer grid with half grid spacing and get derivatives in a staggered like manner. I expect these to have better resolution characteristics, which seems true for 4th order case but not for 2nd order case. It looks exactly the same as non-staggered 2nd order FD scheme, which I can't understand. To me I just halved the grid spacing so I expect the scheme to behave twice as good in terms of wave resolution. I am putting the figure below where x axis is wave number and y is just normalized amplitude.cc- schemes are cell-centered / staggered. My nyquist wave number is 16. I believe that I am doing something wrong but wanted to hear some opinions... Thanks |
April 27, 2016, 16:18 |
Filippo Maria Denaro
Rep Power: 71 |
I do not understand the figure ... you should have the transfer function starting from 1 at k=0, then it should be plotted along the dx*k variable...
for example f(x) = c(k)*exp(i*k*x) -> f'(x) = i*k* f(x) is the exact derivative. The second order central derivative is [f(x+dx)-f(x-dx)]/(2*dx)= 1/(2*dx)*c(k)*[exp[i*k*(x+dx)]-exp[i*k*(x-dx)]= c(k)*exp(i*k*x) *[exp(i*k*dx) - exp(-i*k*dx)]/(2*dx)= f(x)*i*sin(k*dx)/(dx)= i*k_eff*f(x) you see that k_eff/k = sin(k*dx)/(k*dx) is =1 for k*dx = 0 and has the first zero at k*dx=pi. I expect this kind of plot... |
April 27, 2016, 16:28 |
Kaya Onur Dag
Rep Power: 13 |
but you'd expect [f(x+dx/2)-f(x-dx/2)]/(dx) to give a higher resolution than [f(x+dx)-f(x-dx)] /(2*dx) right?
I am also not sure if resolution is the right word there but thats just how I tihink about this. I'll be glad to know if there is a better fit, because I use this often when I talk with people Thanks |
April 27, 2016, 16:39 |
Rep Power: 71 |
[f(x+dx/2)-f(x-dx/2)]/dx=
1/(dx)*c(k)*[exp[i*k*(x+dx/2)]-exp[i*k*(x-dx/2)]= c(k)*exp(i*k*x) *[exp(i*k*dx/2) - exp(-i*k*dx/2)]/dx= f(x)*i*sin(k*dx/2)/(dx/2)= i*k_eff*f(x) you see now that k_eff/k = sin(k*dx/2)/(k*dx/2) therefore it starts from 1 and has the first zero at k*dx/2=pi. Consider that the computational grid introduces the Nyquist frequency at k=pi/dx and you get that the formula has indeed a best spectral resolution. |
April 28, 2016, 10:59 |
Rep Power: 71 |
I forgot to say that the "modified wavenumber analysis" leads to see the "spectral accuracy" of the formula. Actually, (k-keff) is nothing else but the local truncation error in the wavenumber space
April 28, 2016, 11:38 |
Michael Prinkey
Rep Power: 25 |
I can't add much to Prof Denaro's replies. I would note that you ccfd2 results are effectively working on a h-filter width while fd2 works on a 2h-filter width. The transfer function and the empirical response should reflect that. Essentially, fd2(k/2) ~= ccfd2(k). Your plot shows that for fd4(k/2) ~= ccfd4(k), but fd2(k) ~= ccfd2(k) which is clearly wrong.
April 28, 2016, 11:43 |
Rep Power: 71 |
if you are interested in, I have a file with the spectral analysis of many formulas
April 28, 2016, 11:53 |
Kaya Onur Dag
Rep Power: 13 |
April 28, 2016, 14:30 |
#9 |
Rep Power: 71 |
yes, Lele showed that for some compact schemes based on Padè interpolation.
However, my warning is to consider such analysis somehow academic, in practical cases the relevance of the spectral accuracy must be analized for a non linear function. |
April 29, 2016, 05:59 |
#10 |
Kaya Onur Dag
Rep Power: 13 |
Then when you use dealiased fourier series on 2axis and a central finite difference on the other, how would you define the characteristic length scale for say smagorinsky model? Now it doesn t make much sense to me to use sqrt(dx^2+dy^2+dz^2) if you have a smaller dz for this resolution thing. The filter size you want is actaully still the length of the Nyquist wave from one of the fourier axes but dz is much smaller ( just to be able to resolve the same wave )...
or if you had dx=dz then, it would be like applying an explicit filter on z axis each yime you do a finite difference operation |
April 29, 2016, 07:55 |
#11 |
Rep Power: 71 |
if you use pseudospectral codes then it is likey you resolve non-homogeneous and non isotropic turbulence, therefore it is not correct to immagine a single lenght scale.
For example, in a channel flow the normal-to-wall direction has different characteristic lenght scales depending on the distance from wall. In performing LES, is it usual to have a DNS-like resolution along z and define a filter width only in the horizontal plane (homogeneous directions). |
April 29, 2016, 08:46 |
#12 |
Kaya Onur Dag
Rep Power: 13 |
I see, this makes sense for channel flow simulations. I am in the wind energy field and it is not possible to resolve the wall on ground-normal direction but then I can t understand how people define their length scales when they use simple smagorinsky turbulence models.. I know that there is a mismatch because smagorinsky will take energy based on isotropic turbulence yet the generated one is anisotropic and maybe talking about length scales here doesn't make much of a sense. Having said that, I want to know which length scale would be the closest to the real phsics because there is only one number that you change. (?)
April 29, 2016, 08:54 |
#13 | |
Rep Power: 71 |
I suggest to disregard the static model and use the dynamic versione in your problem |
April 29, 2016, 09:05 |
#14 | |
Kaya Onur Dag
Rep Power: 13 |
I 'll change the static version to dynamic model or maybe even plane averaged model after my phd but now I just don't have enough time to implement anything more since I need to hand in something in about 6 months. I appreciate for the comments! |
April 29, 2016, 10:28 |
#15 | |
Rep Power: 71 |
For the neutral ABL, you can find useful the papers of Meneveau about the dynamic and anisotropic SGS models |
Choice of numerical schemes for high accuracy in vorticity | D.B | OpenFOAM Running, Solving & CFD | 1 | February 5, 2018 10:44 |
Influence of schemes on mesh size, orientation and type in a convective flow field | Tobi | OpenFOAM Verification & Validation | 8 | July 16, 2017 08:01 |
High resolution image with parafoam | Andrea_85 | OpenFOAM | 5 | January 23, 2014 06:39 |
Mesh Resolution to resolve turbulent boundary layer | tongx051 | FLUENT | 1 | October 22, 2013 00:18 |
time stepping schemes for compressible DNS/LES | shyamdsundar | Main CFD Forum | 0 | January 14, 2010 23:15 |
