Repost: Cylinder issue
Old   April 25, 2016, 04:06
Default Repost: Cylinder issue
Jens
Hqjen is on a distinguished road
Hi all,
I hope I am not breaking any rules by reposting my thread from another sub-forum, if so, i will of course oblige and correct any mistakes.
However, i posted a question in the StarCCM+ forum last Thursday, which have gotten no replies, so i'm thinking a broader audience might be of help. Original post can be found here: http://www.cfd-online.com/Forums/sta...ar-stress.html
TL;DR:
The shear stresses on the surface of a cylinder are varying very much across the surface. This happens only when the mesh density is increased. The problem is illustraded in the attached figure: Target_Konfig6_Shear Surf.png
The Setup:
Re: 10^6
Models: K-omega SST, Gamma Reynolds Theta
Convective Courant and y+ both under 1
60 prism-layers
~1450 surface cells on the cylinder
Residuals stable and dropping 3 orders of magnitude within each timestep.
I hope someone might give som pointers, or have any experience as to why this might happen.
Sincerely
HQjen
Hqjen is offline   Reply With Quote
Flow past a 2D cylinder - High Re (1E+05) - Cd too high Pervispasco OpenFOAM Running, Solving & CFD 4 March 14, 2022 03:19
[ANSYS Meshing] complicated motion of a rotating cylinder? Vamsi ANSYS Meshing & Geometry 0 April 9, 2016 01:32
3-d mesh gambit (cylinder within a cylinder) Jason ANSYS Meshing & Geometry 29 October 30, 2015 09:59
rotating cylinder using sliding mesh Tim Daly FLUENT 1 November 10, 2008 00:02
Flow over a cylinder Anna Main CFD Forum 9 March 24, 2006 15:32
