Ghady Deeb
Rep Power: 11 ![]() |
Hello, I am studying the compression of Liquid piston using fluent.
My geometry is very simple: Rectangular 2D, with the bottom wall is moving upward with constant velocity=0.01 m/s. I know that I can use the In-Cylinder option for the Dynamic Mesh option, But in my problem I just want the piston to goes up till we hit the Pressure desired inside our cylinder. (compression ratio, r=10 with Pi=1 atm); I read many UDF examples using DEFINE_CG_MOTION, and profile examples. Can someone can help me by telling me what should I write in one the two methods. In my case, there's no force because the velocity is constant, and the moving wall is moving in Y direction. What should I write in the UDF code to tell the piston to stop when the Pressure desired is reached ?? NB: If i use UDF; After I created the dynamic mesh zone for the Moving wall, Should I keep in the boundary conditions, the wall motion for the Moving wall: Stationary ? If yes, it doesn't make sens. If no, then I should give the moving wall, a transitional speed. This point contradicts with UDF ??? Thanks a lot for your help. |
Liquid piston mobile mesh | Ledeeb | Fluent UDF and Scheme Programming | 2 | May 12, 2016 09:06 |
liquid piston cylinder chamber | Mohammed Ejas K S | Fluent Multiphase | 2 | November 11, 2015 00:51 |
Piston Cooling Nozzle Simulation | rajeev50588 | STAR-CCM+ | 1 | February 26, 2013 03:41 |
Piston Simulation | helloworld922 | Autodesk Simulation CFD | 1 | September 9, 2012 22:54 |
liquid piston in horizontal tube | Allen_Lin | FLUENT | 0 | May 30, 2009 03:47 |
