Underrelaxation of pressure correction equation |
April 15, 2016, 19:58 |
Jan
Rep Power: 13 |
Hallo.
When I want to underrelax the pressure equation by the underrelaxation factor lambda, I'm changing the central coefficient aC of the matrix to: aC --> aC/Lambda and the right hand side to b --> b + (1.0 - Lambda) * (aC / Lambda) * p_0 with p_0 is the solution of the last iteration. For p_0 do I have to use: - the old pressure value p_0 - the old pressure correction value (p_0 / Lambda) - 0 Pa as it is a fractional step scheme Thank you in advance. Jan |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
The correction on pressure equation of SIMPLE algorithm in MRFSimpleFOAM solver | renyun0511 | OpenFOAM Running, Solving & CFD | 0 | November 10, 2010 02:47 |
Pressure Correction Equation | morteza | OpenFOAM Running, Solving & CFD | 2 | September 4, 2007 07:16 |
BCs for Pressure Correction Equation (SIMPLE) | Bharath Somayaji | Main CFD Forum | 1 | March 1, 2006 07:12 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
