lift coefficients for 2D shapes
Old   January 6, 2000, 23:12
Default lift coefficients for 2D shapes
Cyrille Douillet
Hi to all, I'm doing a masters of engineering at the Yacht Research Unit of the University of Auckland (New-Zealand). I work on solving the incompressible NS equations on a 2D mast and yacht sail section using composite overlapping grids, with a turbulence model.
I have implemented a routine which calculates the lift and drag coefficients of my sail, and would like to test this on various shapes, such as 2D ellipses at various angles of attack and maybe naca foils. Where can I find these data results to compare to mine (simple inviscid non-turbulent cases would do for the moment)?
I am also looking for pressure distributions around those so I can check if my graphs are correct.
Thank you in advance, sincerely,
Cyrille Douillet
Old   January 7, 2000, 10:40
Default Re: lift coefficients for 2D shapes
Alton J. Reich, P.E.
A good book to get would be "Theory of Wing Sections" by Ira Abbott and Albert Von Doenhoff that is published by Dover Books (ISBN: 0-486-60586-8). It contains geometry, and lift and drag coefficients for a variety of NACA airfoils. For some airfoils there is data at different angles of attack.
lift and drag coefficients around a ground vehicle Pedro CFX 3 September 5, 2012 19:31
how to set lift and drag coefficients in force mon alagesanj FLUENT 0 November 16, 2008 21:47
Lift and Drga coefficients for an airfoil Kevin CFX 4 November 2, 2006 16:48
Lift and Drag Coefficients Reliability Luis FLUENT 2 December 27, 2005 15:45
Lift and Virtual mass coefficients in FLUENT4.5 Vivek Buwa FLUENT 0 November 7, 2001 09:50
