Modelling indoor air flow field - Outlet Static Pressure
Old   April 4, 2016, 18:26
Question Modelling indoor air flow field - Outlet Static Pressure
TheLearner is on a distinguished road
Hello dudes!
I am a begineer in CFD, and I am simulating a retangular enclosure enviroment with forced convection of air. The geometry domain has just one inlet and one outlet.
My boundary conditions are: at the inlet I set the velocity and the turbulent parameters. At the walls I set temperature constant. At the outlet I set the Static Pressure.
My great doubt is about the static pressure at the outlet. My intention is that this outlet simulate na entrance of na air-conditioning system, and my inlet would be the exit of the air-conditioning system.
The question is: Would this outlet pressure be a negative pressure? Or must I set this static pressure as zero? What would be a better practice?
If someone already worked in a problem like this, please help me.
Thank you very much
TheLearner is offline   Reply With Quote
Compressible Flow Pressure Outlet Back Flow okstatecheme OpenFOAM Running, Solving & CFD 1 March 21, 2018 09:11
error message cuteapathy CFX 14 March 20, 2012 07:45
Pressure outlet in two-phase flow in horizontal 2D channel AlmostSurelyRob Main CFD Forum 0 November 17, 2010 08:32
Disturbed flow field at outlet boundary (Multiphase flow through pipe) Michiel CFX 17 April 21, 2010 11:14
Guessing the static pressure needed to produce flow rate jpo FLUENT 0 June 22, 2009 13:53
