Jonah
Rep Power: 10 ![]() |
The hot air from a radiator is not rising in my CFX post contour plots. The wall temperature is set at 40C, with an air inlet of cold air above. The cold air can be seen to flow down onto the radiator, but apart from the area directly around the radiator there is no heat being produced. My Solution convergence wasn't great, so I'm assuming that's the problem but I have no idea what is wrong apart from that...
Please help, Thanks |
ansys, cfx, cht |
2D bubble rising through a column of water | vof64 | Fluent Multiphase | 0 | August 19, 2014 23:42 |
How to compute rising velocity of rising buubles | Nazanin | OpenFOAM Post-Processing | 1 | August 6, 2014 13:19 |
VOF single bubble rising velocity! | Lincoln | Main CFD Forum | 3 | April 10, 2012 10:04 |
bubble rising in a column | swamysrikanth | Main CFD Forum | 2 | September 27, 2010 08:59 |
Pressure rising with temperature | Koranten | FLUENT | 0 | August 19, 2009 05:57 |
