What are the main common steps in CFD modeling of a physical phenomena in software? |
April 1, 2016, 10:22 |
Si Cy
Rep Power: 10 |
I am totally new in CFD. I have worked in Solid mechanics and Material science so I have little bit of experience with FEM of Solids but not Fluids. In FEM software (at least the commercial ones) we use certain steps for example geometrical modeling then applying material then boundary conditions and forces and meshing and solving etc. Is it the same in CFD and FSI ?
What would be the diffreces of FSI and CFD? Is this forum good for FSI too? if not what are your recomendations? Sorry for too many questions Thank you |
April 1, 2016, 11:27 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
Yes, modelling a flow problem is based practically on the same steps and if you think about the elastic equations they are somehow resembling. The main differences that I can say: 1) the relevance of the non-linear terms 2) the relevance of unstedy problems. |
April 1, 2016, 12:03 |
#3 | |
Si Cy
Rep Power: 10 |
In navier stokes formula I remember we were canceling some terms for simplicity (depend on the problem type). How could you do that in CFD softwares especially the commercial ones to save some computational time? |
April 1, 2016, 12:09 |
Rep Power: 73 |
the mesh generation is a fundamental issue also in CFD and is the first step, you need to do... obviously the material can be fluid or solid (a wall for example).
To simplify the NS equations, the classical procedure is to perform a non-dimensional analysis of the various terms. If it appears that some term is less relevant (looking at the corresponding non-dimensional number), then you can simplify that term. For example, small Mach number suggest to use the incompressible flow model. Unfortunately, commercial softwares work with dimensional equations. |
April 1, 2016, 12:47 |
#5 | |
Si Cy
Rep Power: 10 |
April 1, 2016, 12:49 |
#6 | |
Rep Power: 73 |
you can find specific codes for simplified problems...for example, if you assume no-viscosity you can get softwares that solves the Euler equations instead of the Navier-Stokes equations... |
April 1, 2016, 13:03 |
#7 | |
Si Cy
Rep Power: 10 |
P.S these codes are usually for free software not commercial, right? |
April 1, 2016, 13:06 |
#8 | |
Rep Power: 73 |
- OpenFOAM is a free software you can use - Fluent is a commercial and expensive code |
April 1, 2016, 13:12 |
#9 |
Si Cy
Rep Power: 10 |
So within these softwares there are options for users that they can choose which equation or what type of code or solver (Euler, NS , compressible, heat etc) they can use? What is your personal preference on the software? (I know it depends on the type of problem but I would glad to hear peoples experiences and opinions)
April 1, 2016, 13:36 |
#10 |
Rep Power: 73 |
I had experience using both OF and Fluent, but I spent the most of my work using own-made codes.
April 1, 2016, 17:19 |
#11 |
Si Cy
Rep Power: 10 |
Wow, would please tell me what text books are good (or other resources with hands on examples) if I want to start writing my own codes? Do you write and run your codes in Fortran or MATLAB or it is importable or executable by those software you mentioned?
CFD Online Celebrates 20 Years Online | jola | Site News & Announcements | 22 | January 31, 2015 01:30 |
Applicability of a specific software in CFD modelling | ivan-s | Main CFD Forum | 0 | April 22, 2014 14:30 |
CFD Symposium (Call for Papers) | Chris R. Kleijn | Main CFD Forum | 0 | October 5, 1998 11:25 |
ASME CFD Symposium - Call for Papers | Chris R. Kleijn | Main CFD Forum | 0 | September 8, 1998 09:19 |
ASME CFD Symposium - Call for Papers | Chris R. Kleijn | Main CFD Forum | 0 | September 3, 1998 09:45 |
