3-D air motion on multi layer, concentric Cylinders with different heat generation
Old   March 29, 2016, 16:03
Default 3-D air motion on multi layer, concentric Cylinders with different heat generation
behrouz
behrouz is on a distinguished road
hi to all
in one case include three concentric cylinders (inner core and outer core and shell),heat generate in both cylinder with different value(Q1 ,Q2) and initial temperature T1 ,T2. air inter under shell and over the cores and exit to atmosphere.temperature distribution in inner and outer core wanted.
i import the geometry(as uploaded file) from CATIA R20 to ANSYS workbench 2015 and define shell as user defined enclosure and specify the inlet and out let air.
NOW
how i should define other boundary condition???
and can i simulate system in one case or analyse solid and fluid parts separately?
any guide or idea can help
tnx
behrouz is offline   Reply With Quote
Old   April 5, 2016, 10:25
behrouz
i mean in the BC between inner and outer core i should use wall or interior or internal???
3-d, concentric cylinders
Prismatic boundary layer KateEisenhower enGrid 5 September 15, 2015 08:48
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 14:47
heat generation inside fluid omernuke FLUENT 3 May 5, 2010 12:27
heat transfer - heating element to air in FloWorks Duncan Gravill Main CFD Forum 1 March 28, 2007 21:16
TRANSIENT HEAT & BOUYANCY IN CONFINED AIR Carl CFX 1 September 25, 2006 10:48
