Propeller shrouds & Ground effect
Old   March 27, 2016, 22:51
Default Propeller shrouds & Ground effect
srinath
srinath27182 is on a distinguished road
Hi
It is a view held by many that Propeller shrouds increase static thrust. Is this true?
If so why and what design criteria should the shroud meet ?
We all know that when a propeller is brought close to the ground, it experiences an increase in lift.
If we placed a plate directly under the propeller, would the plate+propeller combination experience a net change in thrust?
What if the plate were spinning (and pushing the air outwards--think flow past a spinning disk, that should reduce the pressure build up over the plate)
srinath27182 is offline   Reply With Quote
ground effect, propeller, shroud
full simulation of an aircraft with propeller effect kdrbrk FLUENT 3 January 17, 2024 04:08
Flow Analysis Around Aircraft with Propeller Effect theengineer Mesh Generation & Pre-Processing 0 August 13, 2013 06:37
Ground effect on 2d airfoil stacey FLUENT 0 July 29, 2013 05:18
wing in ground effect meenakshi FLUENT 1 July 12, 2008 14:29
ground effect fluent modelling meenakshi FLUENT 0 June 11, 2008 02:09
