Re- 3.4x10^7- flow wont run properly
Old   March 24, 2016, 20:13
Cool Re- 3.4x10^7- flow wont run properly
Shafee Mohammad
shafee is on a distinguished road
I am doing a case for my dissertation that is due in a week time.
I am running a supersonic flow around a cylinder Re 3.4x10^7. I have been have a problem that i do not know how to resolve. I have tried different mesh sizes. nothing works.
the flow starts with vortex shedding but as soon as it reaches 0.050seconds. the vortex shedding disappears and it the plots do not oscillate any more for lift and drag.
your help with be highly appreciated.
link to the file
https://www.dropbox.com/s/5zbgh4lc3m...0case.sim?dl=0
shafee is offline   Reply With Quote
Old   March 25, 2016, 04:09
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
link to the file
I suppose you are running some turbulence model in URANS formulation, maybe you get too dissipation from the model
FMDenaro is offline   Reply With Quote
Old   March 25, 2016, 13:16
Shafee Mohammad
How do i fix that, any suggestions ?
Old   March 25, 2016, 13:19
Check your type of discretization (upwind supplies artificial viscosity), check you turbulence model and analyze your grid (refine it if necessary).
Did you reach an asymptotic steady state running URANS?
Old   March 25, 2016, 14:26
Shafee Mohammad
I am using send second order discretization. the turbulence model is KE.
you could look at attached picture
https://www.dropbox.com/s/74jgyppptn...23-15.png?dl=0
thanks for your help
Old   March 25, 2016, 14:32
let your simulation run for longer time and see the velocity field in a zoomed region
Old   March 25, 2016, 17:05
Smile
Shafee Mohammad
Fm denaro
i am currently generating smaller mesh.
following are the velocity scenes
https://www.dropbox.com/s/6a7qf13ocm...01-52.png?dl=0
Old   March 25, 2016, 17:06
Shafee Mohammad
Fm denaro
https://www.dropbox.com/s/3vxq3g6evc...02-04.png?dl=0
Old   March 25, 2016, 17:12
you must properly scale them, it is impossible to understand .....
Old   March 25, 2016, 17:27
Shafee Mohammad
https://www.dropbox.com/s/q93mf4lqp6...25-05.png?dl=0
does that help....
you may contact me on
+44(0)7799371737
or on facebook
Shafee Muhammad
thank you very much for your help appreciate it
Old   March 25, 2016, 17:29
Shafee Mohammad
07759735399*
apologies for the wrong numbher
Old   March 25, 2016, 18:37
does that help....
+44(0)7799371737
or on facebook
Shafee Muhammad
still not enough clear this plot ....
however, I suggest to plot the total kinetic energy in the whole domanin versus the time. This way we can check if your simulation has reached a fully developed condition.
Old   March 25, 2016, 19:05
Shafee Mohammad
thank you very much i will try that. it is absolutely driving me crazy ! having a breakdown I have been working on for the past 4-5 months... 6-7 hours daily ! i might end up smashing the computer !
cfd, dissertation, flowaroundcylinder, help in mesh, starccm+
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
How to run cold flow in reactingFoam? harshad88 OpenFOAM Running, Solving & CFD 6 May 17, 2017 05:08
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 14:00
Boundary conditions for flow in nozzle kgevers FLUENT 0 July 26, 2015 13:46
Problem to run flow around a cylinder - LES case valerio galluzzi OpenFOAM Pre-Processing 0 August 26, 2014 08:47
