How can I map the spectrum energy with its associated velocity field?
Old   March 23, 2016, 09:16
Question How can I map the spectrum energy with its associated velocity field?
Julio Mendez
juliom is on a distinguished road
Send a message via Skype™ to juliom
Dear Community, I would like to know if you have tried to map the energy spectrum with its associated velocity field. Imagine that I have the energy spectrum at t=0; E_K(k,t=0)=f(k) where k is the wavenumber.
When we compute the energy spectrum we basically computed the FFT of the velocity (assuming 1D) and the multiply each component by its conjugate and we get the Energy Spectrum. However, during this operation, we lost the connection between the mesh and the wavenumber because we only have half of the wavelengths. This is due to the fact that the FFT goes from N/2-1:k:N/2 or usually we write K=0:N/2 - 1. So that the maximum wavenumber matches with the Nyquist wavenumber.
So, how can we do the inverse process?? I have tried but my solution is meaningless.
Thanks beforehand!!
juliom is offline   Reply With Quote
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 05:49
Editing chtMultiRegionFoam to not solve velocity field tH3f0rC3 OpenFOAM 18 January 24, 2020 17:39
Incompressible Flow: Retrieving Pressure from Velocity Field lordvon Main CFD Forum 9 July 6, 2013 12:24
Why FVM for high-Re flows? Zhong Lei Main CFD Forum 23 May 14, 1999 14:22
