Heat conduction with spatially varying conductivity |
Hello everyone,
I am trying to solve a problem like \nabla(D\nabla T) +f =0 where D is a function of x and y, (x,y being the coordinate system) with some well defined boundary conditions (Dirichlet or Neuman). I want to have a simple FDM discretization like Gauss Seidel or SOR method, but since D is varying spatially I doubt that my simple scheme can work. Does anyone know any better solution? Thanks, |
#2 | |
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
I do not understand your question... GS, SOR are iterative algorithms for solving algebric linear systems, are not FDM discretization... In second order discretization you can proceed for example: [(D* dT/dx)|i+1/2-(D* dT/dx)|i-1/2]/dx |
conduction, fdm, sor |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Heat transfer (conduction) between two pipes | shields | FLUENT | 14 | February 3, 2016 07:45 |
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 13:32 |
Heat conduction problem help | lucky_m_m | Main CFD Forum | 0 | October 17, 2013 08:15 |
