Simulate the pressure in Static Structural
Old   March 18, 2016, 10:28
Exclamation Simulate the pressure in Static Structural
Ali
ali_sharifi990 is on a distinguished road
Hi all, I want to simulate pressure of fluid on the flat plate For effect of pressure on the Deformation, the flow passes through to flat plate, Direction y - Axis that is parallel with plate (Crossing flow in plate heat exchanger).
Now, i setup pressure of fluid in the ansys /Component Y P=500Kpa, Is the correct setting to simulate the fluid pressure in the y-direction?
ali_sharifi990 is offline   Reply With Quote
Old   March 18, 2016, 19:55
Harikrishnan
khnayanar is on a distinguished road
Hello Ali,
There are two forces. One is the force on the wall by static pressure of the fluid and other is the shear force exerted on the wall due to the flow. The static pressure acts normal to the wall and shear force acts parallel. Do you want to simulate both?
Warm regards,
Hari
khnayanar is offline   Reply With Quote
pressure, static, structural analysis
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 14:04
Hydrostatic pressure - static structural stokesy Main CFD Forum 0 March 10, 2015 08:24
Overshooting static pressure guns_down FLUENT 0 March 18, 2014 02:19
Static pressure problem Kiat110616 CFX 0 April 12, 2011 14:11
How to simulate a static pressure sensor ? axel cole Fidelity CFD 1 August 22, 2008 21:01
