What is Boussinesq equation?
Old   December 30, 1999, 17:38
Default What is Boussinesq equation?
Yangang Bao
Hi, there,
Is there anybody who can tell me what is Boussinesq equation? Is it the energy equation + Navier-Stokes equations? Could anybody can tell me where can find some online reference about heat transfer?
Thanks a lot. Have good holiday.
bao
Old   January 3, 2000, 03:32
Default Re: What is Boussinesq equation?
Jonas Larsson
The Boussinesq assumption is that the turbulent stresses are directly proportional to the velocity gradient, ie turbulence can be modeleled as an eddy viscosity.
Old   January 3, 2000, 10:44
COBOK
Jonas, I'm sorry but he was talking about the Boussinesq equations, not the Boussinesq linear stress tensor approximation. The BE may be understood as a simplified version of the full set of Navier-Stokes equations, i.e. continuity, momentum and heat equations. The simplification is attributed to the followings: i) effect of thermal expansion is limited to a linear buoyancy force; ii) usually, viscous dissipation of energy is neglected, and iii) all fluid properties (density, viscosity and thermal diffusivity) are assumed to be constant. In another words, you've got to solve a set of 2*d+1 equations (here d stands for the dimension of the problem). The set is strongly coupled (coupling is stronger than for the NSE for isothermal flows). Good starting would be reading of classical heat transfer books in your local library, not looking for crap on the internet. It's never late to do the latter.
Old   January 3, 2000, 10:55
Jonas Larsson
Ah, that's news to me, I'm sorry if I mislead anyone. I never even heard about the Boussinesq Equations. It is not a very common term in CFD. Thanks for correcting me.
Old   January 3, 2000, 22:53
Thomas P. Abraham
Hello Jonas:
I understand the confusion. Boussinesq approximation you were referring to is found in the Turbulence Modeling literature. Boussinesq equation Yangang Bao was reffering to can be found in classical heat transfer text books. I think it refers to the modifications made to momentum equations while dealing with free convection problems. Unfortunately, both carry the same name.
Probably, one needs to be bit specific when talking about the above.
Thanks,
Thomas
Old   January 4, 2000, 12:27
COBOK
Thomas, yeah, it is quite common that we encounter such confusions. For example, even talking about the Navier-Stokes equations, do people imply only momentum equations, or the full set of equations that govern the phenomena? The problem is with the terminology, though... As for your post, I'd like just to add that the Boussinesq equations are valid not only for free convections problems, but also for mixed ones (free+forced). Once stratification is present and conditions (i)-(iii) in my previous post are met, the full set of NSE reduces to the BE's. Otherwise, the equations are more complex. Regards
Old   January 5, 2000, 04:19
Jonas Bredberg
So.. I would assume that the Boussinesq Equations is the incompressible set of Navier-Stokes equations adding the Boussinesq approximation for the density variation, correct or not? The confusing about Boussinesq isn't total however, since the denotation is Boussinesq hypothesis, or assumption regarding the eddy diffusivity linear relation with velocity gradients. However I maybe adding confusion because this is another Jonas posting this...
Old   January 21, 2000, 22:09
Shi,S
There is one equation about the particle motion in multiphase flow called: "Basset-Boussinesq-Oseen equation". I am not sure if it is what you mentioned. Just for referring.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Viscosity and the Energy Equation Rich Main CFD Forum 0 December 16, 2009 15:01
What is the Boussinesq Term in Momentum Equation CFDtoy Main CFD Forum 0 August 11, 2008 10:56
