March 15, 2016, 07:15 |
Fluent - UDF for Nanofluid homogeneous model
Andrew Vella
Rep Power: 11 |
I am modelling nanofluid flow through a helically coiled tube heat exchanger and I am using multiple UDFs to define the properties of water (single-phase). My question concerns the name allocated to the temperature variable in the UDFs. Should this name be identical for all UDFs? (See attachment)
March 15, 2016, 07:30 |
Cees Haringa
As is noted in the forum description, this is not the FLUENT forum. Please go to the right section with your question.
fluent, nanofluids, udfs |
Fluent Radiation/porous media | Schmitt pierre-Louis | FLUENT | 26 | September 1, 2016 11:29 |
Can Fluent Import New Turbulence Model By UDF? | Andy Cong | FLUENT | 4 | March 25, 2016 14:14 |
udf for condensation model in FLUENT | pushpak | Fluent UDF and Scheme Programming | 0 | November 9, 2013 02:12 |
fluent UDF external library lapack problem | Rick | FLUENT | 0 | May 7, 2008 11:16 |
Reynolds Stress Model in Fluent Vs CFX | Tim | FLUENT | 0 | December 6, 2005 23:03 |
