problem with solving pipe flow in rotating reference frame
Old   March 11, 2016, 16:25
Unhappy problem with solving pipe flow in rotating reference frame
Rodolfo
rpienika is on a distinguished road
Hi all!
I am using a code developed by a Professor of my University (caffa3d), for simulating the flow through an axial pump.
I am working in a rotating reference frame, and I have added Coriolis and centrifugal accelerations, and all the boundary conditions are well applied (at least I think so!)
When I look the tangential component of the relative velocity inside the pipe far away upstream from the pump, it doesn't look like it should. It should have a solid body rotation (because the absolute velocity should be purely axial), but instead it rotates with less magnitude.
I have tested a simpler case of the flow inside a circular pipe (without pump) with several boundary conditions at outlet (zero gradient, zero total derivative, constant pressure) but all of them give the same result.
Anyone have an idea why this occurs?
Thanks!
rpienika is offline   Reply With Quote
axial pump, rotating reference frame, tangential velocity
Cannot run the code properly: very large time step continuity error crst15 OpenFOAM Running, Solving & CFD 9 December 14, 2014 19:17
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 05:13
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 01:34
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
