Plane subdivision around jet stream
Old   February 29, 2016, 06:47
Default Plane subdivision around jet stream
Deependra
Deependra is on a distinguished road
Hallo Guys,
I am doing a jet flow simulation in a rectangular box. Actually I want to perform co-simulation of CFD and more coarse zonal model. Regarding this, after achieving jet propagation inside box, I want to calculate mass flow on all surrounded planes of this stream. This needs to be done on subdivision of each plane.
So after getting mass flow on surrounding zone of this stream, can be given as input to my other model.
Could you please let me know that, how can it be done as post processing in Ansys fluent or other Ansys module.
Please share the information, if some body has any idea about it.
Thanks
Regards
Deependra
Deependra is offline   Reply With Quote
2D Plane Jet Fluent Solution doug Main CFD Forum 11 February 4, 2019 10:34
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
Impinging free surface water jet on a flat plane NicoMa STAR-CCM+ 0 July 7, 2015 07:15
Reduction of Jet noise by using a extra stream scsheen Main CFD Forum 3 May 6, 2003 06:20
jet stream test case Vincent FLUENT 0 July 9, 2002 05:45
