CFD-DEM Simulation - Particle Size compared to mesh cell size |
Nadish Saini
Rep Power: 12 ![]() |
Hello Foamers,
I have a conceptual question to which i am not able to find an answer. I am performing ONE-WAY coupled simulation of micron sized particles suspended in a turbulent flow field. The concentration of particles is low enough for me to consider only one-way coupling. i am solving the flow field using LES. The mesh cell size is generally larger than the particle size. However, near the wall, since LES requires DNS type resolution, the mesh cells are smaller than the particle dimensions. My questions: 1. For one-way coupled simulations, is it necessary to have the condition that particles must be smaller than mesh cells? 2. There must be a way to deal with the situation where DEM particles are larger than mesh cells but i could not find any reference article for it. Can someone please guide me with this. Thanks a ton! |
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
I think your question is more general than an OF problem...
Specifically, I think there is no physical meaning in having a computational mesh size smaller than the particle diameter... Do your particles have a relevant inertia? |
#3 | |
Nadish Saini
I am not sure what you mean when you say: "there is no physical meaning in having a computational mesh size smaller than the particle diameter". The particles i am considering have a mean diameter of 200e-6 m. Thus their inertia would be small, no doubt. The smallest cell dimension (near wall) is 12e-6 m for LES simulation. |
If the particle covers the computational cell You cannot solve the fluid equations there
#5 | |
ali
Rep Power: 10 ![]() |
I have a problem similar to your problem but for two-way coupled simulation! I have simulated the CFD step and now I want to run coupled CFD-DEM that DEM particles are larger than some mesh cells especially near wall. What must I do? Did you find a solution? Thank you |
bambang
Rep Power: 8 ![]() |
Hello, I am a newcomer in CFD. I have one question. What the weakness of PIV if compare to the CFD especially in in-cylinder engine flow. Thank you.
[ICEM] Effect of globle mesh size and mesh independency | sujay | ANSYS Meshing & Geometry | 20 | September 29, 2019 07:36 |
[snappyHexMesh] crash sHM | H25E | OpenFOAM Meshing & Mesh Conversion | 11 | November 10, 2014 11:27 |
Inner geometry gets lost exporting mesh from ICEM CFD to CFX-Pre | powpow | CFX | 3 | December 20, 2012 09:14 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
