How to calculate swirl velocity or angular velocity in a in-cylinder flow analysis us
Old   February 23, 2016, 11:07
Default How to calculate swirl velocity or angular velocity in a in-cylinder flow analysis us
Gomathi shankar
tgsankar is on a distinguished road
I am doing an in-cylinder steady state flow analysis. In that I need to calculate the angular velocity of air rotating
about the cylinder axis. I have been using a custom field function to monitor the velocity. The field function is
given as: (x*Vz-z*Vx)/(x*x+z*z). While using this field function the velocity fluctuates between a maximum and
minimum valve. It does not settle or converge even the solution is converged.
I need to know whether the field function is correct or wrong? Why the value fluctuates?
I really need this explanation which will help me in my project work.
If anybody experienced this same issue, please let me know.
Thanks in advance.
tgsankar is offline   Reply With Quote
Old   February 23, 2016, 13:25
Matt
fluid23 is on a distinguished road
Depending on what software you are using, you can probably setup a cylindrical coordinate system and then treat it just like x y z components except get axial, tangential and radial flow velocities.
fluid23 is offline   Reply With Quote
Old   April 26, 2017, 17:55
Default Curl of the velocity field
Muhammad Zahid
zkhn is on a distinguished road
You have to calculate \nabla\timesV, i.e curl of the velocity field.
zkhn is offline   Reply With Quote
cylinder flow, swirl, swirl ratio
how to give swirl flow in 3D cylinder by using fluent 6.3 shivampm FLUENT 4 January 28, 2019 05:52
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 07:24
Appropriate flow velocity for basic 2d analysis Lukasz Mosakowski FLUENT 1 February 14, 2006 09:58
In a swirl flow, how to show tangetial velocity Wang FLUENT 1 October 27, 2000 04:59
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
