Surface Evolver Water Droplet Modeling
Old   February 23, 2016, 00:04
Default Surface Evolver Water Droplet Modeling
Actuallyah is on a distinguished road
I'm trying to model hydrophobic surfaces using Surface Evolver. The shapes of these surfaces are grid like structures of cubes. In order to model the surface tension I need to develop a constraint function that accounts for the cubes in the surface. So far my attempts have failed to develop anything that accurately follows the structure. I have attached an example surface I've built that does not include any tension modeling. In order to view it you will need to change the extension to .fe and run it with Surface Evolver. If anyone could help me understand how to model the surface tension I would greatly appreciate it.
Actuallyah is offline   Reply With Quote
Old   June 17, 2016, 21:29
Kimia is on a distinguished road
Hi.
I want to do a similar project with surface evolver.
For my project, I defined a patterned surface exactly like the one you modeled. but I don't know how to apply proper constraints to model the contact of the fluid with the solid surface.
Have you by any chance figured out the solution to your problem?
Thank you.
Kimia is offline   Reply With Quote
Old   June 17, 2016, 21:30
Hi.
Thank you.
Old   June 23, 2020, 17:17
The_seeker is on a distinguished road
Hi All
I am working on creating kelvin wet foam in Surface Evolver. There exist a significant amount of studies where people studied the random foam structures using Surface Evolver. The steps mentioned on the website are simple, however I am not able to convert dry foam to wet foam. I first run the twointor.fe and create dry Kelvin cells. Then I type read "wetfoam2.cmd" in command terminal followed by wetfoam >>> "wetfile .fe". But when I try to open the wetfile it shows the following error.
The_seeker is offline   Reply With Quote
Old   June 23, 2020, 17:18
Hi All
I am working on creating kelvin wet foam in Surface Evolver. There exist a significant amount of studies where people studied the random foam structures using Surface Evolver. The steps mentioned on the website are simple, however I am not able to convert dry foam to wet foam. I first run the twointor.fe and create dry Kelvin cells. Then I type read "wetfoam2.cmd" in command terminal followed by wetfoam >>> "wetfile .fe". But when I try to open the wetfile it shows the following error of 'redefinition of identifier border_body'.
Mass imbalance problem in multiphase water and steam CFX case Antech CFX 1 October 26, 2020 05:03
initialize open channel flow with a know water surface profile Ema40 Fluent Multiphase 4 February 21, 2016 12:31
Water droplet on surface, problems with interface water/air (video / setup included) silent2608 Fluent Multiphase 1 December 7, 2015 04:40
Simulation of varying contact angles for a large droplet of water on a surface cp703 CFX 5 July 20, 2013 07:08
SSIIM 2, vertical elevation of the water surface, transient water flow parameters Mummputz Main CFD Forum 6 November 18, 2012 14:39
